Differences between Camaro and Vette LS1 ?
Old May 4, 2006 | 11:31 PM
Chevy4Life's Avatar
Default Differences between Camaro and Vette LS1 ?
Well, the oil pump went out on my 98 Camaro and the motor is toast. My dad was lookin at replacin it with a LS1 with 30k miles out of a 98 Vette. What are the differences between one out of a 98 COrvette and one out of a 98 Camaro? Better? Worse? Throw me some input guys.
Old May 5, 2006 | 12:23 AM
ssheets's Avatar
I think the only difference is the vettes have drive by wire, that is the throttlebody has a servo that drives instead of a cable. Other than that they are the same motors...oh and some Camaros came with dino oil from the factory and some came with synthetic. All vette LS1s came with synthetic as I recall.
I think the Vettes have a different oil pan to, but you'll be re-using the throttle body and oil pan so if it's a good deal go for it.
Old May 5, 2006 | 02:35 AM
prostock_bigblock's Avatar
No difference at all, except for accessories ,PCM,oil pan, and elec TB .
Old May 5, 2006 | 03:19 AM
WsSickLs6's Avatar
no way guys...The Vette had 350hp and the camarrow had only 305hp...With the extra 20k you got 45 extra hp just for being in a corvette...
Old May 5, 2006 | 03:22 AM
nickls1's Avatar
yeah youre definitely going to have to swap out the oil pan too because its a different shape and the vette pan is bigger and wont fit.
Old May 5, 2006 | 03:38 AM
ThirdGenLS1's Avatar
Your going to have to swap out the TB for a cable one, and swap the oil pan out for a f-body one. But since you have an exsisting LS1 just grab those parts off it and drop it in.
Justin
Old May 5, 2006 | 04:19 PM
Chevy4Life's Avatar
cool, thanks a lot for your input guys. I knew about the throttle body, but I'm glad i asked because i didn't know about the oil pan.
Old May 5, 2006 | 06:30 PM
kossuth's Avatar
Camshaft if also different guys. The cam in the Vette is actually alittle hotter than the stock fbody cam. You probiably won't see a difference though from one to the other.
Old May 5, 2006 | 06:35 PM
yea I was just referring to what would be different reguarding for him to drop it in.
