Request for proper block break in procedure
Old May 5, 2006 | 08:43 AM
LS1-450's Avatar
Default Request for proper block (engine) break in procedure
Am in the process of chaning my LS1 block to an assembled LS6 block complete w/L7 pistons, timing set, melling oil pump. Will use existing AFR heads, Comp cam, intake, oil pan, & covers. What is the correct way to break in the new block? Is there a write up somewhere? Thanks in advance.
BTW, can't wait to do away w/the 99 LS1 PCV arrangement.
Last edited by LS1-450; May 5, 2006 at 10:32 AM. Reason: added (engine) to the title
Old May 5, 2006 | 01:29 PM
LS1-450's Avatar
to the top
Old May 5, 2006 | 01:36 PM
Orange Peel's Avatar
Drive it like you would after break in, don't cruise at one speed, change the revs up, rev it out some, decel off the engine, etc, etc. I dynoed my new motor at 375 miles, just change the oil before dynoing it or at 500 miles, then you're good to go lay the hammer down
shouldaboughttheZ's Avatar
http://www.crateenginedepot.com/suinst.html
A friend of mine sent me this link when we were talking about breaking in his engine.
Old May 5, 2006 | 02:59 PM
LS1-450's Avatar
Thanks guys, I appreciate the comments.
