few question
Old May 5, 2006 | 10:37 AM
sierra's Avatar
Default few question
hi again
i have few question to ask i hope that i find answers
1# what is the best gear ratio for GMC SIERRA truck ??3.73,4.10,4.56 or other
2# i want to buy cams for my truck any suggestion ?? how much gain will i get ?
3#what is the best supercharger for GMC SIERRA A/T ,, and how much gain willi get ?
4# if i installed supercharger is it true :- *Air mass ,Throtelbody, and air filter must be remove ?
5# i wanna a fuel pump , beacuse my mechanic said '' the onw in the car right now has aweak pressure " which fuel is good to buy ?
finally i have hypertech programmer i found some difficulty with A/T transmission shift point ?? did work with any ??
thank you all
Old May 5, 2006 | 12:20 PM
ShevrolayZ28's Avatar
Originally Posted by sierra
hi again
Hi there. I hope you're staying safe over there.
I'm no expert but I'll take a stab at a few of your questions and if nothing else, get the ball rolling for others to chime in.
This choice will depend on what you decide to use as a camshaft.
It only uses one cam . This seems to be the $60k question around here lol. I would consult with the truck guys in the truck forum. I'd say that you'll want a cam that features lots of low end torque, to get that beast rolling, especially if you plan to move heavy loads or tow a trailer. So to that end, what are your goals? Sport truck? Heavy hauler? A little of both?
I've seen some folks posting great results from turbo systems. Gobs of torque down low! Again, check out the truck forum for more info.
I don't know but a lot of the kits come with all the stuff you need to make the install.
You should wait until you decide on your induction setup (blower/turbo). Most of the kits either come with fuel system upgrades, or at least make recommendations as to what is appropriate.
thank you all
You're welcome, even though I wasn't much help lol.
Here's a link to the truck forum:
http://www.performancetrucks.net/forums/
