New Texas Speed Camshafts & PRC Heads Combo NEWS!
#121
The PRC LS6 heads will work well as a budget head with just about any cam setup. I would rather run a Dart 205 for a couple hundred dollars more with the cams you mentioned, but if you want to keep it around 1k those are the way to go.
#131
How much for a complete package Heads, .650 springs , camshaft, pushrods, all gaskets for 2000 ls1 head cam swap, ported oilpump, timing chain , will the ls2 chain be alright ? pacsetters , true dual x-pipe ' bullets , and a tune . only want to pay shipping once
#133
Originally Posted by Uthinkso
Just a question, but aren't the LSK lobes designed for low RPM big blocks and not really intended for high RPM that the LS1 spins to?
What is a low rpm big block???..ask Patrick G how the LSK lobes do at high RPM's..
#134
This thread definately died. What happened guys? Where's the technical info?
I'm about to pull the trigger on a heads/cam setup, and I can't make up my mind based off of hopes and dreams....
#139
Originally Posted by Marc '99T/A
I'm guessing you didn't call them....?
i'm still gonna wait for it though
