Finally!!!
Old May 5, 2006 | 01:46 PM
blkbird's Avatar
Default Finally!!!
Well, I finally got my cam installed and it sounds awesome!! I am pretty pleased the the install went rather smoothly. All I need now is a good tune and get the most out of it. Pulls pretty hard in the midrange. I got a lot of help from people here on this site. Thanks. Now I just got to get my rear end fixed (pinion and carrier bearings).....
Old May 5, 2006 | 02:04 PM
nokeman's Avatar
Congrats!!! What are the specs of ur cam???
Old May 5, 2006 | 02:09 PM
blkbird's Avatar
Its the infamous hotcam 219/228 .525/.525. on a 112.
Oh yeah, I also put in a new oil pump and LS2 timing chain. Just turned over 90k so I thought it wouldnt hurt. That pick up tube was a pain in the @$$.
Old May 5, 2006 | 06:52 PM
HaulinHawk's Avatar
Congrats!!!
Old May 5, 2006 | 08:34 PM
blkbird's Avatar
The only problem I have is that it keeps dying when I turn on the a/c. Obviously because of the extra load. Will the tuning take care of that problem?
Old May 5, 2006 | 11:22 PM
kartoon's Avatar
what kind of oil pump did you go with? and did you just do the chain or did you get the t/c set?
Old May 5, 2006 | 11:48 PM
ShevrolayZ28's Avatar
It should.
Hey, did you blow the rear end before or after the cam? lol
Congrats on the upgrade!
Old May 6, 2006 | 01:15 AM
blkbird's Avatar
kartoon: I used the LS2 timing chain and the LS6 oil pump (which is the standard replacement when ordered).
ShrevolayZ28: My rear end started going out a couple of months before my cam install. I hope tuning takes care of the problem cuz it gets hot as hell here in TX!!!
Old May 6, 2006 | 04:44 AM
CASHss99's Avatar
congrats man,,, im going with sum afr heads and a good sized cam not sure yet... congrats tho
Old May 6, 2006 | 06:48 AM
blkbird's Avatar
Thanks guys...
Old May 8, 2006 | 10:25 AM
TwoFast's Avatar
yeah your tune will get rid of your car dying with the a/c on. Mine also did that after I installed my hot cam, but it all went away after my tune. good luck. hot cam sounds nice doesn't it
