59cc or 64cc heads ?
Old May 6, 2006 | 07:09 PM
MKS's Avatar
MKS
Default 59cc or 64cc heads ?
2002 A4 with a TR CheaTR cam and full boltons and im between these 2 patriot ls6 stage 2 heads
Assy. 2.02"/1.57"/59cc
Assy. 2.02"/1.57"/64cc
car has ported stock 241 heads right now
Old May 6, 2006 | 07:54 PM
8GTOKLR's Avatar
your ported stockers should be fine..what valves do you have in stockers? the 64cc is octane freindly
Old May 6, 2006 | 08:04 PM
MKS's Avatar
MKS
they are just ported with stock valves so they are basicllay stock and need to be upgraded
Old May 6, 2006 | 08:08 PM
8GTOKLR's Avatar
save money if you upgrade your port job, then get new stainless valves rather than buying a whole new set of heads. if money isnt issue then get AFR Stage 2 64cc
Old May 6, 2006 | 09:10 PM
MKS's Avatar
MKS
it will cost me to get the valves and double springs and thats why im getting the patriots with the gold springs and bigger valves but not sure which cc and what pushrod size need
Old May 6, 2006 | 09:26 PM
Ksett's Avatar
Go with the 59 cc's and check the pushrod length and you will be set.
Old May 6, 2006 | 09:51 PM
LS1Cryo's Avatar
It depends on what your plans are for the car personally i would go with the 64's.
Old May 6, 2006 | 11:54 PM
Rescue Ranger's Avatar
I had 59cc ran great no problems at all, used normal 93 octane. 59cc = 11:1 CR 64cc = 10.6:1. I'd personally go 62cc or 59cc for N/A application.
Old May 7, 2006 | 01:26 AM
PREDATOR-Z's Avatar
11.35 SCR is the compression you'll have with 59 cc
But looking at your sig, $$$ shouldn't be a problem for you (unless you're a car dealer), so I suggest to get AFR milled to specs with the size gasket he was running.
PM him, he'll set you up for the best CheaTR combo.
Old May 7, 2006 | 06:12 AM
Phil'sC5vette's Avatar
My AFRs are milled to 63cc. Close to the line, but nothing to have to worry about
Old May 7, 2006 | 06:20 AM
1bdindn's Avatar
You need to find out the intake closing point at .006" on your cam and then figure your dynamic compression. Keep it around 8.5/1 and your good.
Old May 7, 2006 | 08:55 AM
MKS's Avatar
MKS
Thanks alot guys for the help im calling tomorrow to order the 59cc
Old May 7, 2006 | 08:56 AM
MKS's Avatar
MKS
do you know what size pushrods with with the 2.02 59cc
Old May 7, 2006 | 09:31 AM
PREDATOR-Z's Avatar
I would go 7.425
Old May 7, 2006 | 10:04 AM
Chevy99's Avatar
59cc is the way.
Old May 7, 2006 | 03:32 PM
MKS's Avatar
MKS
Thanks again
