Spun bearing or collapsed lifter?
Old May 11, 2006 | 02:39 PM
goodol'93z's Avatar
Default Spun bearing or collapsed lifter?
over reved the motor, then the motor started knocking, sounded like it was coming from the top of the motor so figure it was probably a collapsed lifter. i take the heads off (checked pushrods rockers etc.) and all the lifters apear to be ok. the roller ***** show only normal wear a roll smoothly.the weird thing is that i found a piece metal (looked like a small piece of aliminum foil) on one of the lifters. could it be that i spun a bearing?. or could the lifter have internal damage eventhough externally it still looks new. by the way motor was built around 4k miles ago.forged pistons, lunati rods, arp rod bolts race coated bearings, ls6 ported oil pump, block has ported oil passeges but a reused the stock crank, the entire rotating assembly was balanced also. the car is a 98z m6
Old May 11, 2006 | 02:47 PM
Z'mnypit's Avatar
Whats your oil pressure look like? Have you changed the oil to see if there was any flakes?
Old May 11, 2006 | 02:50 PM
zaner's Avatar
I Went Through This Same Process With My 98 Ta. When This Happened To My Motor, It Turned Out To Be A Spun Bearing.so My Vote Goes For Spun Bearing
Old May 11, 2006 | 05:29 PM
goodol'93z's Avatar
oil pressure is @ 40psi at idle and goes up as it revs
zaner did you just replace the bearings, how hard was that. i have done many h/c swaps on both ls1 and lt1 but have never messed with bottom ends. should i take it to a shop? really dont want to. thanx
Old May 11, 2006 | 05:42 PM
01SS346's Avatar
sounds like a spun bearing to me
Old May 11, 2006 | 06:11 PM
chriswtx's Avatar
Any metal flakes in the oil??
Old May 12, 2006 | 11:16 AM
goodol'93z's Avatar
havent checked the oil yet i will do that tonight. do you guys think i spun a rod or main bearing. how to tell which is broken, i need some guidence. remember the motor has lunati pro mod rods w/arp bolts thanks for all the responses. chriswtx the car is in kyle, tx. not to far from you
Old May 12, 2006 | 01:03 PM
BRIAN98Z28's Avatar
that is EXACTLY to the T what happened in my 98 car, and it WAS in fact a spun rod bearing......sorry to hear that bro, especially after you had the motor built for the car
Old May 12, 2006 | 01:07 PM
zaner's Avatar
I sold that motor to a guy wanting to do a swap into a non lsx vehicle, he didnt mind the bearing was spun and planned to rebuild it anyways. I took that money teamedit w/ a little more and bought a built ls1 w/ 34,000 miles.
Old May 13, 2006 | 12:05 AM
cantdrv65's Avatar
Post
Yep, defintely sounds like a rod bearing....
Old May 13, 2006 | 12:14 AM
SHINER's Avatar
it could be bearing babbit. food for thought.
Old May 13, 2006 | 12:32 AM
92zcamaroperson's Avatar
how high did you rev it out of curiosity? i would think that a forged motor like you have should take quite a beating.
Old May 13, 2006 | 01:32 AM
PREDATOR-Z's Avatar
If it is on a 98 block, they had oiling issues. That is why even GM modified the blocks mid 99.
I would never use a 97>98 block for a rebuilt.
Old May 13, 2006 | 01:59 AM
cantdrv65's Avatar
Post
I remember when I had my 99z28 if I ran it lower than 1qt low on the stick and reved the snot out of it the oil pressure would actually start to DROP! Not good. When it was full of oil I never saw a problem. I ran quite a few bottles of N2O through that engine however and it did have over 100,000 miles.
Old May 13, 2006 | 11:02 AM
SHINER's Avatar
so what causes the oiling issues? was it poor pump design?? Im gonna get a ported LS6 pump soon hope i wont have this issue!
Old May 13, 2006 | 11:20 AM
PREDATOR-Z's Avatar
No it was block core design.
Old May 13, 2006 | 11:23 AM
SHINER's Avatar
**** so i guess if the car was made in 1998 for 1999 i have a **** block?
Old May 13, 2006 | 11:49 AM
PREDATOR-Z's Avatar
Well, not really; it just means that they are not the best for rebuilts and high power applications.
Let us say they were improved upon.
Old May 26, 2006 | 12:55 AM
98M6SS's Avatar
What exactly does the knocking sound like?
Old May 26, 2006 | 01:06 AM
98_LS1's Avatar
happened to me... sorry to say, but sounds like a spun bearing
