Is my block fixable???
Old May 11, 2006 | 03:20 PM
SDMForever's Avatar
Exclamation Is my block fixable???
Okay guys I was finishing up my rebuild I have done over the past month and when I went to start it I had problems. At first the car would act like it had no spark plugs and never really start up.
Then It started to do this...
I figured something is wrong and pulled my heads and this is what I found...
and...
I thought I had my timing perfect...
The specs on the cam are 221/221 .558/.558 116 lsa Lunati Pn 55099
and I even had stock rocker arms and pushrods in for the startup.
Is my block fixable after the crack in the water jacket? WTF do I do?
Old May 11, 2006 | 03:24 PM
KY Z28's Avatar
OMG, thats bad man. any idea what happened? sorry to see that
Old May 11, 2006 | 03:25 PM
REDWS6ROCKET's Avatar
looks like a valve spring keeper came out and dropped a valve. timing marks are lined up, what else could have happened
Old May 11, 2006 | 03:39 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
That block will make a nice paper weight.
Old May 11, 2006 | 04:59 PM
Aegnor's Avatar
Darton has sleeves that might fix it. But for the price of the sleeves and machining, how far would you be from just getting a new 402 or another LS1?
Plus a new motor could come with a warranty...
Old May 11, 2006 | 05:18 PM
SDMForever's Avatar
Did I do anything wrong?
Old May 11, 2006 | 05:32 PM
calongo_SS's Avatar
Yes, lol
Isn't there two differnt marks on the gear for the double roller chain?
Is there damage in every cylinder?
Old May 11, 2006 | 05:36 PM
01SS346's Avatar
wow I dont know you could re-sleave it but you would spend as much as a new motor might as well go with a new motor
Old May 11, 2006 | 05:41 PM
SDMForever's Avatar
No there isnt damage and there arent 2 marks the damage is only to like 3 of the pistons.
Only 1 needs to be resleeved... but I think there is a crack in the block by the water jacket.
Also one of the bad ports on the drside head there is a crack on the wall between it and the water jacket... I think the heads were bad.
Old May 11, 2006 | 05:48 PM
calongo_SS's Avatar
Bad heads don't cause valves to hit pistons. This has happened before with doulble rollers not being set up properly. I don't know the details, b/c I've never personally dealt with one.
Old May 11, 2006 | 05:55 PM
SDMForever's Avatar
how could you set it up wrong there is a key to help you... You just line up the dots.
Old May 11, 2006 | 06:04 PM
chriswtx's Avatar
Ouch that sucks. There is 3 different key ways on a double roller, I forget the exact directions, but there is a specific way to line everything up..
You can get a brand new LS6 block from Texas speed for $599. Would be cheaper than fixing that block..
Old May 11, 2006 | 06:29 PM
SDMForever's Avatar
Is it even possible to fix the water jacket?
Old May 11, 2006 | 06:32 PM
chriswtx's Avatar
you would have to ship it off to some one who has experience resleving and have it resleved. Very expensive...
Old May 11, 2006 | 07:01 PM
SDMForever's Avatar
There is also a crack in the water jacket... huh
Old May 11, 2006 | 07:06 PM
chriswtx's Avatar
Yeah, trash the block and start over...
Old May 11, 2006 | 07:09 PM
SDMForever's Avatar
What is the best way to do this?
When I pull outh the engine should I pull the trans with it, and what is the easiest/cheapest way to get a block... maybe its time to get my stroker setup... can I use my block still if I go a bigger bore?
Old May 11, 2006 | 08:52 PM
brad8266's Avatar
Use a lift and unbolt the cradle/engine/tranny then lift the car from the motor assembly.
Old May 11, 2006 | 09:10 PM
SDMForever's Avatar
what should I do with the block
Old May 11, 2006 | 09:16 PM
67Ranger's Avatar
sell it to a scrap yard... aluminum will get you at least some money
