Help me spec perfect cam for forged 346 LS6 D1SC motor on the boost and off boost!
I am going to be running 9:5 to 1 compression on a Forged 346 LS6 motor (which i am going to start having built in the near future) for my 02 Z06, powered by my ECS D1SC Procharger kit, which is a street car and will see between 8 to 14 lbs of boost at any given time on the street and occassional track day (both roadracing and a little drag racing). Also, important to note that i am going to be running my new forged set-up with my 100% stock LS6 head (except for valve train upgrades for the new cam).
I want a fairly agressive cam without going to big, which will make great power off the boost and on the boost of course, and am thinking of something like a 226/232 cam on a 114lsa, with a .588 lift. or 224/230, 114, .588 lift.
What cam do you EXPERTS here recommend for me for the my custom CAM specs for the use of my car as described here.
I certainly don't mind running a little bit more of an aggressive cam similar to the specs set forth above, but don't want to overdo it as my 02 Z06 is primarily a street car, but would like to have a nice midrange HP increase when i am not seeing boost and running the car between 2000 to 3000 rpm, etc., but of course most importantly, I need the cam to perform like a champ when seeing anywhere between 8 to 14 lbs of boost at any give time!
THANKS and yes, I also posted this in the F/I section, but am not getting as much feedback as I would like!
LS1 Tech Administrator
IMO, you want the exhaust lobe to mimick the valve events of what you would need if making 600-650 rwhp on motor, but you'll need a shorter intake lobe and narrower LSA to keep the overlap under control. High lift on the intake lobe would make the curtain area larger, allowing more pressurized air to enter.
Something like a Thunder Racing CheaTR (215/230 .600/.578 117LSA) would be great, but I would go a little bigger:
220/236 .632/602 114LSA +0
Running a lot of intake duration is not necessary, but plenty of exhaust duration is. Power off boost will be good because of the shorter intake valve timing.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
