No Compression In 3 Cylinders!!!!
Old May 12, 2006 | 05:24 AM
TheHawk's Avatar
Default No Compression In 3 Cylinders!!!!
Hey, guys... got the news that I don't have any compression in 3 of my cylinders. What are some of the causes of that?
They said it was the cam... but if it was the cam then wouldn't all 8 cylinders fail?
Old May 12, 2006 | 05:28 AM
PREDATOR-Z's Avatar
Do a leakdown.
Old May 12, 2006 | 05:33 AM
TheHawk's Avatar
Originally Posted by PREDATOR-Z
Do a leakdown.
Thanks for the response. What is a leakdown? What does it do?
Old May 12, 2006 | 05:47 AM
PREDATOR-Z's Avatar
It will determine if pressure is lost via valve seals or via rings.
then you know if it is rebuild time or just seal change time.
Old May 12, 2006 | 06:10 AM
zo6vetteman2003's Avatar
I agree. Could be rings or seals. Better hope it is seals.
Old May 12, 2006 | 09:11 AM
KGSloan's Avatar
how would it tell you if the valve seals are leaking??? that doesn't make much sense to me.
it would show you if your actualy valves aren't sealing, or if your rings aren't sealing. maybe that's what you said and i miss read it
Old May 12, 2006 | 09:30 AM
PREDATOR-Z's Avatar
Maybe I word it wrong (darn half breed that i am )
If the valves are sealing or not or if the rings are loosing the pressure.
He could have valves hanging open, or not seating properly or rings are shut.
Old May 12, 2006 | 09:35 AM
rocketman442's Avatar
^^^ Your right a leakdown just shows where the combustion chamber is leaking (ex. rings, valve, or to the coolant thru a blown head gasket of thru a cracked head or block)
Old May 12, 2006 | 10:23 AM
KGSloan's Avatar
ok, i just didn't understand what you meant, wanted it to be clear for everyones sake
Old May 12, 2006 | 05:30 PM
98REDZ's Avatar
hope this isn't my problem too, checked 2 of my cylinders yesterday and im good...Anthony may be comin over tonight to check stuff out Kit so i'll let ya know how it goes
Old May 13, 2006 | 06:25 AM
TheHawk's Avatar
YAY!!! 4 Cylinders busted. One of my rollers screwed up and chewed through the harden steel of my cam and stripped one of the lifters. It's great!!! Tranny busted. YAY!!! Clutch... busted!!! YAY!!!
So here I am... having a great week!!! Would this be a full engine rebuild build? If so... wouldn't Z06 parts (ie heads and clutch) be a simple swap?
Old May 13, 2006 | 07:34 AM
LS1-450's Avatar
I feel yah. I'm in the middle of a block swap because of two bad cylinders. Why not get a "new" assembled block & cam. Then re-use the heads, intake,...etc.? Although, if you went this route, a new clutch & trans. would be best. Am not sure about this, but, I think interchangability is from 98-2002 & then 2003 & up. So, you may not be able to mix & match w/Z06 parts. You probably could go w/ a new or used Z06 engine, clutch, trans. to replace everything you have & modify your mounts if required.
