Oil pump O ring
Old May 12, 2006 | 08:16 PM
killaz's Avatar
Default Oil pump O ring
Replacing my ls1 pump with a ls6 pump. Can i use the old o ring? If not can i get a link to where i can get a new one from.
Adam
Old May 12, 2006 | 08:29 PM
blkbird's Avatar
Do not reuse the old one. The dealer is your best bet for it. Its only about $4.
Old May 12, 2006 | 10:03 PM
ssbodyman's Avatar
Just inspect the old one and and check its condition. You should get a new one put I just replaced my oil pump with the port LS6 and it kind of pissed me off that a new OP doesnt come with a new O-ring and tried to get one at the local parts store to no avail and just reused it since it looked new and it worked fine, just be sure to get it in right and lube it good with oil before you install it.
Old May 12, 2006 | 10:12 PM
slowpoke96z28's Avatar
if the o-ring has any kind of deformity to it, get a new one. it would suck to have to do the job over because of low oil pressure. the whole point of messing with the oil pump was to ensure the engine had a dependable source of oil, so why risk the whole job to save a couple bucks by using the old o-ring?
Old May 12, 2006 | 10:48 PM
staringback05's Avatar
id get a new one just to make sure, its not worth the hassle for a 4 dollar part
Old May 13, 2006 | 12:16 PM
Red99C5's Avatar
You can use the old one if it's not damaged, but why take the chance with the labor involved. Seems stupid to sell people an oil pump without a new o-ring. I don't understand that. I just got a new LS4 pump, and no o-ring with it either.
Old May 13, 2006 | 12:34 PM
ShevrolayZ28's Avatar
Adam
Lots of o-ring talk today....
You should not reuse the o-ring. In addition to what the other fellas have mentioned, there are two different style pick up tubes that call for different o-rings. One has a reciever groove, and one doesn't. The one with the groove needs the thicker O-ring, I think its a brown O-ring. The rest use the blue/green O-ring.
Make sure you have the right one, *correctly installed*, and it should be new!
Old May 13, 2006 | 02:13 PM
good info shevrolayz28
Old May 13, 2006 | 04:02 PM
SUX2BU's Avatar
i used to inspect them and reuse them. but after a perfect looking o ring had low oil pressure and i had to replace it. it was double the work for nothing. I know put a new o ring in EVERY time.
Old May 15, 2006 | 11:59 AM
you2slo's Avatar
So which O-ring goes with the LS6 pump?
Old May 15, 2006 | 12:10 PM
According to ACW's sticky post in the General forum, the LS6 oil pump o-ring seal = p# 12557752.
Old May 15, 2006 | 12:53 PM
slt200mph's Avatar
The LS 1 and the LS 6 oil pump have the same part number..just checked in the parts dept. computer..I work in a chevy dealer. Always change the O ring..they can be purchased at any GM dealer parts dept. It is too much work to have to go back in install another one after you button everything up and have a oil pressure issue to deal with..they are cheep and very criticle to the engines life span..
Seems that this has been discussed a zillion times??
Old May 15, 2006 | 10:18 PM
badpewter-z's Avatar
LS1TECH Sponsor
deffiently just get a new one you DO NOT wanna find out after you get it all back together that you get to do the job again we keep atleast 5 on the shelf at my dealer
