Cam on 35th ss M6
Old May 15, 2006 | 10:32 PM
2002camaross35th's Avatar
Default Cam on 35th ss M6
Ok so i have a 35th anniversary camaro ss M6 with Qtp Longtubes, ORY, airlid, K&N filter, and 4.10's in the stock 10 bolt. I was very intrested in getting the T-rex from thunder racing. I have read many forms and from what i've heard so far is the cam isn't streetable. What is the next best kind of cam i can get that will give me sumthin close to the T-rex power and torque wise,but will have alright street drivability? The car is a weekend car and will see the track when necessary. Whats yar opinion?
Old May 15, 2006 | 11:04 PM
Turo's Avatar
I believe TSP's MS3 is right up there withthe TRex and it has better street manners (from what I've read). Someone with more experience feel free to chime in.
Old May 16, 2006 | 12:17 AM
Yea i've heard about the ms3 giving alot of comp. to the t-rex. Also i was readin up about Patrick G.'s cam which i think is based of the Trak cam. His cam also sounds pretty intresting
Old May 16, 2006 | 12:20 AM
SSilverSSurfer's Avatar
Trak is bad ***....ms3 smaller than the Trex but it makes good power under the curve...so does the S cam which is what i have....the Trex is so awesome though...ive seen up to 440hp cam only with that cam
Old May 16, 2006 | 12:45 AM
Yea so far i guess i have the Trak or the Ms3 to chose from. Basically whats the difference betweent the 2 cams, for instance the difference in the mid-high power ranges. Also people that are runnin these 2 cams, what kind of Power are you gettin and whats yur setup. Also if anybody has a different cam that im leavin out, let me know. Thanks for all the help guys.
Old May 16, 2006 | 01:23 AM
67camaro's Avatar
check this out:https://ls1tech.com/forums/dynamometer-results-comparisons/502495-promised-trak-full-bolt-ons-90-90-a.html
Old May 16, 2006 | 03:47 AM
LS1ROPER's Avatar
[QUOTE=67camaro]check this out:https://ls1tech.com/forums/showthread.php?t=502495[/QUOT
NICE THREAD HAVE THIS CAM IN SHOP WAITING FOR INSTALL,ALONG W/LS6 HEADS!
Old May 16, 2006 | 04:48 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
All you need is a decent tune and you can run the T-Rex daily.
Old May 16, 2006 | 08:53 AM
HOSS's Avatar
Exactly. With a great tune, the T-Rex could be streetable with time. You would need to do some part throttle tuning also on it, not just the WOT stuff. If you don't want to go that large, I would go with Thunder's next cam, the TRak. I am making killer power off this thing, and with a dyno tune, I am going to go for closer to 440 cam only. As far as under the curve power, I am making more than the MS3 graphs I have seen at peak power, and under the curve. Good luck!
Old May 16, 2006 | 08:54 AM
MagikMan's Avatar
Rock out the f13
Old May 16, 2006 | 05:32 PM
Hey hoss, what kind of springs are you runnin with that Trak. Looks like you got a pretty good set up there man, with real good numbers too. Thanks for all the help guys, i really appreciate it
Old May 16, 2006 | 06:53 PM
HOSS's Avatar
comp 921's, and I appreciate it man
Old May 16, 2006 | 08:20 PM
WS6FirebirdTA00's Avatar
The TRak cam is a great cam, along with all of Thunders other cams. I wouldnt hesitate to call them up about a cam. When it comes to cams, do it right the first time.
Old May 16, 2006 | 08:30 PM
mailman2000's Avatar
g5x4 or g5x3 ?
