Anyone bent a pushrod???
Old May 18, 2006 | 09:12 PM
bernieblackbird's Avatar
Default Anyone bent a pushrod???
Just wondering, because I did I am pulling the head off tomorrow. I just wondered what you may have encounter when you pulled your head off?? Piston damage???
Old May 18, 2006 | 09:17 PM
Matt281's Avatar
bent some on my tuned port motor when i went to start it after my first cam install..didnt need to replace anything put the pushrods..
found that i had the timing chain gears way off when i pulled it apart to diagnose the problem..*skakes head*
Old May 18, 2006 | 09:20 PM
LS144's Avatar
Just did it the other day havent had a chance to look at the internals yet. You dont have to pull it all apart just do a leakdown test if you have the tools....If you do pull the heads off take them and get em ported while theyre off.
Old May 18, 2006 | 09:21 PM
LS144's Avatar
Did the EXACT SAME THING SUNDAY Hoping to only change pushrods.
Old May 19, 2006 | 12:43 AM
hoping tha there is nothing that is in bad shape when I look, allready done a leakdown test 0% percent. Pulled the valve cover broken valve sping that went over the top of the retainer that pinned the valve down = NO CHANCE FOR THE SECONDARY SPING TO PULL IT UP. To bad I only had 5,000 miles on my heads
I think that I am going to buy Patriot heads
Old May 19, 2006 | 01:00 AM
Lithium's Avatar
SSU's Drunk Typing Whore
Impressive
Old May 20, 2006 | 09:35 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The motor must have been screaming when they bent. DAMN
Old May 20, 2006 | 10:44 AM
LS144's Avatar
Sounded like an industrial sewing machine lol
