iron block question...
Old May 19, 2006 | 02:38 PM
JL ws-6's Avatar
Race your car!
Default iron block question...
I'm in the process of planning out an iron block 402... afr heads, big cam, etc.etc. I will be reusing alot of parts of my stock motor... but I'm wonderign if any of the engine covers arediffernet from the 6.0 iron block from teh alum 5.7 block. Oil pump covers/timing covers, etc.etc that kind of stuff.
If they are, which ones are needed, part #'s would be great, so I can try to find some for sale in here, or at a junkyard, whatever.
Thanks.
Old May 19, 2006 | 04:02 PM
Chicago Crew UnderBoss's Avatar
Default iron block
It is my understanding that 1000% of all the LS1 and 6.0 liter ironblock components, covers, oil pump, etc., etc., are interchangeable, and i am sure someone soon here will confirm my opinion that you will BE GOOD TO GO!!!
Old May 19, 2006 | 04:10 PM
JL ws-6's Avatar
Race your car!
thanks, that's good to know. Hopefully someone elase will chime in and confirm.
Old May 19, 2006 | 05:12 PM
2001 Pewter WS6's Avatar
Restricted User
I used all my covers from my old motor when I built my iron block 408
Old May 19, 2006 | 06:20 PM
Bandit28's Avatar
you will have no problem with the parts they will all bolt on you will just need extended cam sensor wire and knock sensor wires
Old May 19, 2006 | 06:30 PM
Restricted User
Not for an iron block... for an LS2 6.0 block you would.
Old May 19, 2006 | 06:39 PM
xaon's Avatar
ditto that. I used all the covers, gaskets, sensors, etc from my stock motor on my iron 408/AFR setup.
Old May 20, 2006 | 06:45 AM
JL ws-6's Avatar
Race your car!
Thanks guys, that makes life easier, no need to be running around at junkyards looking for engine covers now.
What about the alternator bracket? I was planning on going to that bmr drag race only bracket as the power steering and heat/ac are going away, does that bracket work o.k.? I have read from a couple people that it does, but not exactly the way it should.....
Old May 20, 2006 | 11:15 AM
xaon's Avatar
i'm not sure about the BMR bracket, on the factory alternator bracket you have to leave out one bolt.
Old May 20, 2006 | 01:24 PM
JL ws-6's Avatar
Race your car!
probably the same with the BMR one then I"d guess. Is it o.k. with the bolt missing?
Old May 20, 2006 | 02:30 PM
1999TransamWs6's Avatar
You will have no problems leaving the bolt out.
