head swap gasket question
Old May 19, 2006 | 02:40 PM
WS6nJAX's Avatar
Restricted User
Default head swap gasket question
Going to be installing a set of .030 milled heads with an f-13 cam. Do you think .045 cometic gaskets will be ok?
Old May 19, 2006 | 02:54 PM
GuitsBoy's Avatar
Im guessing you dont have valve reliefs. Im going to say that its gonna be too tight. I wouldnt chance it. Start making preparations to notch the pistons and forget about your P to V problems.
Old May 19, 2006 | 03:56 PM
ArcticZ28's Avatar
Why don't you want to use the GM MLS gaskets?
Old May 19, 2006 | 11:39 PM
WS6nJAX's Avatar
Restricted User
so with a stock gasket i should be ok?
Old May 20, 2006 | 12:10 AM
Xtnct00WS6's Avatar
If it were me, I'd make sure to measure the ptv clearance. I'm betting you're gonna be really close.
Old May 20, 2006 | 12:23 AM
WS6nJAX's Avatar
Restricted User
the guy i got it from ran stock gaskets and stock length push rods. i planned on going to a 7.35 and thought going from .056 to .045 on the gaskets would be right in line.
