Damn it..broke a cam retainer bolt..pic..help?
My question is will it be alright with only three bolts holding it on?
I was torqing them down to 18lbs and gave it just an little extra tug and the head of the bolt broke off and i think it fell in the damn oil pan because i cannot find it anywhere else....
pulling the oil pan isnt a problem cause the tranny is gonna come out for a new clutch which will make easy to pull out. Still damn annoying though.
everything was going so good to...damit.
damn that sucks man..hopfully someone will shime in..but if i was you i would start by tring to find the head while your waiting..dont want that thing in the motor on startup....
i gave up looking for the bolt tonight...tomorrow after work i will start pulling the tranny and then the oil pan and see if i cant get it out of there...it has to be in there.
bastage!!!! i love working hard to put in new stuff to go faster or handle/look better...but i hate fixing crap that breaks! i do it..but its just depressing some times...lol
to do it right you need to remove the old bolt either with an extractor or drill and tap. and replace the bolt, you also need to find the other end. not a good idea to have it in the oil pan. try removing the drain plug and putting a magnet in there. might be small enough to remove that way. just and idea.
tomorrow i will try to get the bolt head out...i might be able to catch it with vice grips...i tryed with some plyers breifly to no avail. I will try again.
But there is no way that bolt head will come out of the drain...i have to drop it down an inch and stick my magnet in there to find it.
then i will roll over to a pontiac dealer tomorrow and order some new bolts and a oil temp sensor ....
i will let you all know what happens
But in other news...here goes the magic stick
I'd pull the plate off and try to use a bolt extractor kit (sears has a good one). If that doesn't work, you can use a screw extractor. Either way, find the head of the bolt!
same here, no issues with the arp hardware, second the paranoid. Also might be a good time to get your toque wrench calibrated again, you should not have broke those at 18 and a little, maybe like 30 ft lbs, but not 23 or so. If you have a crappy torque wrench, might be time to toss it.
Originally Posted by kartoon
a hammer and a small screwdriver works for us on aircraft. just have a little patience. you should be able to get it out.
Originally Posted by NassyVette
Yup, there should be enough material left on the screw to punch it counter clock wise till the tip backs out enough to grab with some pliers.
Ahh...sucess...i used a small punch and hammer and got it to spin counter clock wise out, then grabbed it with some pliers!!!
you guys rock..!
now i just have to find the head of the damn bolt...
*goes to garage to drop oil pan 1/2 *
Would you happen to know the part numner for these ARP bolts?
Originally Posted by digitalsolo
I have ARP bolts on that plate. They were like 9 bucks. Have them on the cam sprocket also.
I'm paranoid.
I'm paranoid.
