Bad lifter??
Old May 22, 2006 | 10:56 PM
nokeman's Avatar
Default Bad lifter??
Ok so Ive had the infamous ticking for about 6 months now. Ive changed to hardened pushrods this weekend and all my plugs and wires are nice and tight and it still ticks. Im starting to think I have a bad lifter. My question is, is that a major problem that is difficult to fix. Would it be expensive to have someone fix it?
Old May 23, 2006 | 02:40 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It would be labor for pulling the heads so you are looking at around 750-1200 just in labor for most places.
Old May 23, 2006 | 04:52 AM
LS1TORQ's Avatar
does your ticking noise go away after the engine warms up? say about 10 mins? Mine does, just wondering if i have bad lifter too.
Old May 23, 2006 | 05:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The bad lifter will pretty much be a constant tick.
Old May 23, 2006 | 10:34 AM
nokeman's Avatar
Nope...its a constant tick. Would changing them be something I can do on my own??
Old May 23, 2006 | 03:04 PM
TSDuke's Avatar
Have you checked your valve springs? Might have a cracked, broken one??
Old May 23, 2006 | 09:44 PM
nokeman's Avatar
No I havent checked em yet. I didnt know that could be a cause of the noise. Those are being changed out very soon anyway.
Old May 23, 2006 | 11:10 PM
ShevrolayZ28's Avatar
There are so many cars that tick, LS1tech should have a "car ticking" subforum.
My car ticks for a few minutes half way through a cold start, then it stops. I can only guess what is causing it. I'll see what I can see once I get around to installing a H/C combo.
Old May 24, 2006 | 08:01 PM
nokeman's Avatar
So can anyone tell me if changing the lifters will be something that is not too difficult to do?
Old May 24, 2006 | 09:29 PM
Bandit28's Avatar
you will have to pull the heads and intake off and get all new head bolts and head gaskets plus the cost of your lifters and get the torque sequence and you could do it if you feel comfortable takeing your heads off... alot of ppl with ls based engines have lifter ticks and they still seem to run fine its up to you its not that tought to pull that heads off, goodluck
