trex question
Old May 22, 2006 | 11:08 PM
TheCarKid's Avatar
Question trex question
How is the TReX cam with nitrous? Nothing more than 125 shot. Am I asking for trouble?
Old May 23, 2006 | 12:59 AM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
Your bottom end might be asking for trouble. The T-rex will feed off of nitrous because of the split grind. You should search on this. There is probably enough info out there about this that the search will overload and break from the high yield.
Old May 23, 2006 | 07:40 AM
TheCarKid's Avatar
I've heard that LS1's handle nitrous really well.
Old May 23, 2006 | 01:00 PM
SVT THIS's Avatar
Some people will say you may dump some of it out the exhaust but I doubt it will yield anything less than 125hp from a 125 shot. Your biggest enemy is going to be your stall. You will have to have around a 4400 stall with the TRex cam to get the most out of it, and if you spray on that off the line you will flash to 5k+ and be at your rev limiter in no time-unless you have some reeeeal sticky tires!
Old May 23, 2006 | 01:03 PM
CrawlinWS6's Avatar
Import Patrol
T-rex here, with a 150 shot and a 4000 stall. I will have results sunday night!
Old May 23, 2006 | 01:11 PM
TheCarKid's Avatar
Don't worry bout the stall, it's a 6spd.
Old May 23, 2006 | 01:13 PM
TheCarKid's Avatar
CrawlinWS6 keep me updated on how it goes. Do you have stock bottom end?
Old May 23, 2006 | 11:03 PM
SMOKIN01TA's Avatar
i plan to spray mine if it holds up till then, probably atleast a 150 shot
Old May 23, 2006 | 11:11 PM
moeZ28's Avatar
I know a guy that took a stock bottom end LS1 with headers, lid, cutout, TREX, 4800 stall, and a 225 shot, stock 98 intake, a stock 3.23 gear, and BFG drags and went 6.50's in the 1/8. I would say they do well with nitrous.
