Procharer Or MOTOR?
Old May 24, 2006 | 02:59 PM
Donws6's Avatar
Default Procharer Or MOTOR?
I dont know what to do! I want to get more power cheaper without running N2O! I have a 99 ws6 and have about 5000 to 7000 to spend so help me! I also want to know if vortec is better than procharger!
Old May 24, 2006 | 03:06 PM
conan's Avatar
How about both
Old May 24, 2006 | 03:09 PM
Donws6's Avatar
Well i would but the money i have is not enough money! My plan is to go procharger d1sc and get heads and cam made but i dont know who i should send them to! NAd i want to put new pistions in and then rods and a ford 9" rear end and reabuild trans! Can i get 580 to the wheels like every one says?
exSSer's Avatar
You can't spend that much and get more than a nice H/C setup. You can SC for the bucks and get quite a bit more power than with a H/C, but you'll have to consider more driveline upgrades to handle the extra torque.
Old May 24, 2006 | 03:13 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Don't forget about the compression change that will be necessary to run the extra boost if you so chose. I say H/C and intake and maybe a 125 shot if you were considering FI. You will be happy either way though man. Happy Modding.
Old May 24, 2006 | 03:16 PM
Donws6's Avatar
Default But
I dont want nitrous and i want to know cuz a guy named sean collins says i will never to put that in my car and it wont make that much power! So i need to know the best way to go for the power i want and keep it an every day driveing car!
Old May 24, 2006 | 03:18 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
N I T R O U S....that is and will always be best bang for buck combo. Screw Sean Collins.
Old May 24, 2006 | 03:21 PM
Donws6's Avatar
I dont want Nirtous that is what i am saying!!!
Old May 24, 2006 | 03:22 PM
98redorangeta's Avatar
I say get a 408 now then sell your stock motor and put a procharger on it later
Old May 24, 2006 | 03:24 PM
Donws6's Avatar
Ok well i thought that through too but for the money a procharger would be a good way to go! I want to run 10s and i want to know if i can and how to set it up with out n2o!
Old May 24, 2006 | 03:29 PM
Honestly you will probly get more power out of a 408 NA than you will out of the stock motor with the procharger #7 rod bolt and 500 hp are not buddys.
Old May 24, 2006 | 03:33 PM
Donws6's Avatar
Ok but i was going to order new Dimond pistions and rod along with the procharger! But my orginal question is What is the better way to get power for the money i have to spend? I dont want nitrous!!!! I want to keep my Ws6 ANd every day driving car
Old May 24, 2006 | 03:35 PM
Allergik2dyin's Avatar
S/C, but I really wanted to know why you put an exclamation point after every sentence!! haha
Old May 24, 2006 | 03:38 PM
Donws6's Avatar
I am really confused and frustrated with this!!! I have the money and need to know.
General Jack's Avatar
I'went through a similar decision process recently. While I want big power, I had to weigh that against the fact this car is my daily driver and needs to be reliable. I've been running a cam for over 2 1/2 years now with little problem, so technically the decision for me was heads v pro charger.
While a forced induction LS1 is way cool, in the end my head won out and I ordered Stage 2e heads from MTI to go along with my current mods. Ordered the heads this past Monday in fact.
What I should end up in few weeks (when I get the heads installed) is a very reliable 500 crank horsepower, mid 11 second daily driver.
Old May 24, 2006 | 03:39 PM
Ryan'sSS's Avatar
Call up Hardcore tell them what you want out of your car and they will hook you up. They are a Procharger dealer, so that should make you happy.
Old May 24, 2006 | 03:40 PM
Donws6's Avatar
Well if i do H/C package who should i get my heads from? I want to run Cooks 1 3/4 headders and magnaflow exhust with no cats!
Old May 24, 2006 | 03:41 PM
Donws6's Avatar
Can i get the #? To hardcore
Old May 24, 2006 | 03:48 PM
98Z28MASS's Avatar
are you an A4 or M6? I say get a nice heads/cam package, say maybe an MS3 and prc ls6 heads (should be about $2500 for everything), then headers, and a moser 12 bolt. With tune, install, and other needed mods, such as fueling, you should be around 450 rwhp, and with a stick tire and good suspension you would certainly be in the 11's, and maybe 10's if you know how to launch well. FI is always WAY more expensive than you initally think it will be.
98Z28MASS's Avatar
TSP is actually having a sale of their H/C packages
