titanium retainers???
Old May 25, 2006 | 12:27 AM
vader99's Avatar
Default titanium retainers???
Should I go with titanium retainers with the tr 224 224 cam or are the stock retainers good enough for this application?
Do you actually notice a power difference with the titanium retainers or is it primarily to extend the safety margin against valve float?
Old May 25, 2006 | 12:32 AM
Robinator's Avatar
they are all around better than stockers and lighter wieght for higher reving. I dont think you will see any power difference at all.
Old May 25, 2006 | 01:37 AM
1ImperialSS's Avatar
formerly silverbrick (changed 02/17/2013)
you dont really need them, save your money for better things or get a biggger cam if you want to make good use of the retainers
Old May 25, 2006 | 06:41 AM
Studytime's Avatar
Being that the top of your spring is smaller in diameter than the bottom of your spring ("beehive design"), it makes a Ti even less important.
It would be hard to fully justify them for a 224-sized cam with stock springs.
Ben T.
Old May 25, 2006 | 10:35 AM
steveo346's Avatar
I Have Them With My Cam Setup And I Heard The Extend The Longevity Of The Springs
