would i need this with h/c install
ls6 intake
timing chain
ported oil pump
ls6 intake
timing chain
ported oil pump
Head bolts
oil/filter
coolant
lube
crank pulley bolt
water pump gaskets
front seal
front cover gasket
valve cover gaskets
intake gaskets
tools
rags
first aid kit
some beers
patience
+miscalleneous
and most important (a TUNE)
I wanted my ride ready to drop something bigger in and be able to keep it from overheating, and have a drive shaft, clutch, rearend, and brakes that can handle what it puts out. I am thinking a forged 408 with a good amount of boost, and some custom intercooling so I don't have to worry about losing efficiency. I want my Forced Induction project to be as consistent as my N/A is now. Give Bobby a call at LG Motorsports 1-972-429-1963 and tell him Doug sent ya. They saved me thousands by making my order/install a custom pkg because so much of my work could be done at once. Example Clutch, Rearend, Driveshaft with only one labor charge because it all comes apart anyway to get the clutch out. So I replaced the drive shaft and rear at to avoid doing it later and spending more. Good luck.
VIPER, if you are looking for anything give him a shout as well. Anyone on LS1tech will get any discount available if my name is mentioned.
Had I not put in all the OT I did I wouldn't have replaced everything. Also had Lou not extended me some credit I couldn't have done it.
As far as getting charge double for covering the same ground, it happens all the time. You call a shop and say I want this and this and this done. They write it down as 1. 2. and 3 and then proceed to bill you in that way. I was quoted $1500-$1800 to have my cam and oil pump, timing chain replaced. I asked the guy if he was serious. He said yep and quoted me the times from the book. I said your already in there why are you charging me twice to cover the same ground? He said this is what the book says. If it deosnt take me as long you'll be charged accordingly. I say no thank you goodbye.
I do the cam, headers, oil pump timing chain valve springs all by myself in my garage with the aid of a bungee cord (just like the directions say). So when it came time for the heads I didnt even think about calling anyone. They were easier than the cam and oil pump and headers.
If you just cant do it yourself and have to pay someone it might be worth a 5 hr drive to save hundreds of dollars. Thats something you need to seriously weigh out.
Extra money spent on labor that could be money spent on more parts.
PS..... You will need deep pockets.... If that is the shop you are getting to do the cam install.
LG Motorsports experience and have gained other things in the relationship that I am not sharing with the forum. My perks only.
talk about customer service
way to go LG
