View Poll Results: Which heads should I get????
Patriot Stg 3 5.3 Heads
43
27.22%
AFR 225cc Heads
83
52.53%
Other
32
20.25%
Voters: 158. You may not vote on this poll
Can't decide AFR 225cc or Patriot Stage 3 5.3 heads, most HP per $
Old 12-07-2006 | 02:29 AM
  #41
PICNIC_GEORGE's Avatar
Originally Posted by SpdFrk1990
Do you have to mod the valve covers for rocker clearance or anything for the tfs heads?
I don't think there is any clearance issues. However TFS does say not to use stock rocker arms on those heads. Not sure why but I'll find out.
Old 01-24-2007 | 12:22 PM
  #42
DONAIMIAN's Avatar
Id say the 5.3's since im assuming its a stock cube motor. You already have the cores, and the 5.3 numbers are right in line with LS6 numbers (both flow and HP)
Quick Reply: Can't decide AFR 225cc or Patriot Stage 3 5.3 heads, most HP per $
