What heads 4 stroker
Old May 26, 2006 | 07:08 PM
jeremym's Avatar
Default What heads 4 stroker
What heads to get for 414 stroker. ET's,custom LS6's, or custom 6.0's. My comp. is 12 to 1 with my 98 LS1 heads. I want the most power N/A
Old May 26, 2006 | 08:20 PM
xfactor_pitbulls's Avatar
You want the most power huh...............LS7 with an LS7 intake. Or the 255cc ETs. Everything else is going to run a distant second. I wish I or anyone else for the matter could do an LSX casting to keep up with either, but it isnt going to happen. You wanna be the big dog, get either of those.
Brandon
Old May 26, 2006 | 11:42 PM
jeremym's Avatar
Brandon
Thanks Man I called ET today and they said the 245cc would be perfect but I will check those out.
Old May 27, 2006 | 12:17 AM
Imagine that, you called ET and they said an ET head would be perfect . Good luck with it.
Brandon
Old May 27, 2006 | 12:18 AM
98vortecbw's Avatar
how about ported 225 afr's???
Old May 27, 2006 | 07:24 AM
jeremym's Avatar
would the fast 90/90 keep up w/ the ET's flow or would it choke it?
Old May 27, 2006 | 03:35 PM
You should run a big ported vic jr setup with 90mm or 105mm TB. That would be good for 20+ on top of the fast. If you do keep the fast, atleast get it ported.
Brandon
Old May 27, 2006 | 07:36 PM
jeremym's Avatar
Brandon
Where do I get that or what do I look up to find that stuff?
Old May 27, 2006 | 10:56 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default 245 ls7
Actually for the best results, I would reccommend the etpls7 4"bore heads with the LS7 manifold kit. I have seen big power with this combo, not far off from the big dogg ls7
