Taking the bloody engine out the top now...
Now think about that statement and the audience you're talking about. I guarantee less than 5% have their own lift, most guys balk at spending $1200 on headers, having a lift in the garage is not exactly cheap.
And we do it using rhino ramps and jack stands. ALL of it from tranny swaps, clutch changes, full exhaust work, and oh my no power tools!!
Oh, and Kory, don't throw in the towel man.
I expect it to be harder going back in, only because I need to worry about lining bolts back up as I drop the frame back down, but that shouldn't be too bad at all. Shouldn't even need a new alignment like some people say because the 4 bolts on each side aren't adjustable. You don't even touch the adjustable part of the suspension.
Should have the new motor in this weekend once all the rest of my parts come in.
Used nothing but a breaker bar, a couple sockets, ratchets, and wrenches, two jackstands, two ramps, an engine hoist, and 6 tires to stack underneath the framerails to lay the car on while being k-member-less. Only "special" tool I needed was the fuel line quick disconnect tool my g/f picked up for me at Autozone.
TraverAbsolutely!
There is a reason that the GM manual for our cars clearly says that the engine was designed to come out the bottom...
I wonder how many of the guys that claim taking it out the top is easier even have a GM manual (and have READ it)...
I use my hoist (mostly) to hold the engine from the top while I am taking stuff loose. Then to lower the engine and tranny down onto a dolly.
