PTV Clearance with milled 243's and TR224
Do these numbers look about right?!?!
30*Before TDC = 410
25*Before TDC = 335
20*Before TDC = 275
15*Before TDC = 215
10*Before TDC = 180
5 *Before TDC = 155
TDC = 163
5* After TDC = 190
10*After TDC = 230
15*After TDC = 290
20*After TDC = 375
25*After TDC = 470
30*After TDC = 560
I found exact TDC by putting a piston stop in the spark plug hole when both intake and exhaust valves were closed (I could tell is was about TDC too because of how far I could push the valve down) and then rotated the engine backwards (counterclockwise??). I then marked the spot on the degree wheel. I then rotated the engine in the normal rotation (clockwise??) and then marked a spot on the degree wheel. The position between those two spots is supposed to be exactly where TDC is. That's the correct procedure right?
Thanks!
I double checked those numbers and now I'm getting 60 and 65ish at TDC? What gives?
OK...I just got back from checking again. I don't know how on earth I got 60 and 65 at TDC before. I've tried to duplicate those results with no avail. I checked a bunch of times and got 179, 109, 170, 175, 165, 185, 174 and 156. These numbers seem a bit high don't they?
Don't my numbers at TDC seem high to anyone though?
Again my setup is 243's milled .010, with .045 gasket and a TR224 cam on 114.
My lowest numbers ended up being around 2* after TDC. They were usually about 3-6 thousands less than the numbers at TDC.
Thanks,
Dave
What kinda numbers did u all have (in regards to ptv clearance) with similiar setups?
