SO who here runs a BIG cam on the street?
I dont see why you would wnat a big cam on the street. Chances are you are going to have shitty DCR and the bottom end would suck. For a street car, it would be pointless under a certain rpm, as it woudl feel like stock. The trend for "small" cams is because a big cam wont do much more for you. A proper setup and a smaller cam will make a more powerful car all day long, every rpm range.
Originally Posted by 02NBMWS6
232/234 .595 .598 cam, lid, headers, pulley 430whp. 409wtq
It can be a bitch at times, especially without good tuning, but you get really used to it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by WS6FirebirdTA00
You shouldnt start the car with the AC on in the first place...
(Oh and that really doesn't answer my question, because even if i turn the air on after its started it still dips down to like 4-500rpm a few times before it idles at ~1100).
Educate me
All about the person driving it as far a driveability. ran a 230/236 107lsa cam in my daily driver for a long time. bout to run a .754"/.760" lift cam in my current street car, not a daily driver any more though.
#33
I drove a friend of mine's GTO with LTs, LS6 heads and G5x3 cam. After a few weeks of tuning he got the tune figured out (HPTuners) and it was a blast to drive. It pulled like mad from 4000-6700(redline). Under 4000 it was a little doggy but when you can rev it up to 6700, who spends time under 4000?
#36
TRex here with a 4000 stall daily driven.
WS6FirebirdTA00 I have to disagree with you. A properly done setup with a small cam WILL outperform a poorly done setup with a large cam. However, if you do both the right way, there is no way in hell a small cam can begin to touch the power with a big cam. Do you see any 224 cams in the cam only records????
#37
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
And I am not saying a 224 cam will hold a cam only record
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#38
Originally Posted by Ωmega
244/250 - 4400 stall - no power steering - bad transmission
I would drive it everyday if I wasnt so worried about the trans leaving me stranded.![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
