tick tick tick.....solved
Old May 29, 2006 | 11:25 PM
mxmccarter2401's Avatar
Default tick tick tick.....solved
well my car started to tick and after searching i found that this problem was common with many ls1's. so i pulled the valve covers and all appeared to be normal. i checked the torque on the rocker arms and they were all fine. i was prepared to pull the heads and remove a bad lifter but when i pulled my push rods out i found one that was bent to ****. i'll post a pic later. so anybody else with the "ls1tick.com" problem check your push rods. later,matt.
Old May 30, 2006 | 12:02 AM
tsench's Avatar
thx for the info
Old May 30, 2006 | 08:35 AM
GuitsBoy's Avatar
Glad to hear you got it fixed. Its pretty popular, especially after an overrev. Better the pushrod than a valve.
Old May 30, 2006 | 08:37 AM
keliente's Avatar
My thoughts exactly. I have replaced 3 banana'd pushrods after a mis-shift myself.
