H or I rods?
Old May 30, 2006 | 01:42 AM
Gregory's Avatar
Default H or I rods?
In putting together a stroker engine I have a choice of H and I shaped rods.
What is the experience others have had with these rods, and what are the weight differences?
Thanks!
Old May 30, 2006 | 01:46 AM
stang90gt50's Avatar
H-beam in non billet style rods are generally much stronger. I-beams are often lighter, but its of minor significance.
Just go with a set of Eagle or SCAT 6.125" H-beams. Both can be had for $350-450 depending on where you buy them. Both will easily live up to and above 1000hp...
no reason to do much else.
Old May 30, 2006 | 11:43 PM
Gregory's Avatar
Thanks. I'm 99% sure that Shafiroff Race Engines will build the engine. Tomorrow I make the decision and call in the order. Shafiroff uses 4340 Callies "Comp Star" 6.125 H-Beam Rods with ARP 2000 Rod Bolts.
Old May 31, 2006 | 05:06 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Nothing wrong with a good set of h-beams. Most people do that for stregth anyways.
Old May 31, 2006 | 07:11 AM
Demon SS's Avatar
excellent choice!
