Pushrod length check
Old May 30, 2006 | 04:39 PM
TchargedLS1TA's Avatar
Default Pushrod length check
Im wondering if someone out there who is good at engine math can figure out the length I need. I went from .030" milled 6.0L head to stock 6.0L heads and a .051" gasket.. 7.400"s are too short. Im thinking 7.45" might be what i need
Old May 30, 2006 | 05:46 PM
heavymetals's Avatar
Rather then taking an educated guess, why not spring for a checker?
They are less then $20.
However, a good set of calipers that measure under 8" are a bit pricey.
Old May 30, 2006 | 05:48 PM
Well Im in a rush and the pushrod length checker I have wont fit in an LS1 pushrod hole...
Old May 30, 2006 | 05:56 PM
I have seen a substitute made out of two spokes screwed into the tightener (rim nub was ground off).
Pretty skinny but it worked.
