59cc Dart heads, 90/90, G5X3 cam install is complete.
Originally Posted by SVT THIS
Do you know what your compression is with that gasket, mill and cam?? I will be running a TRex and would like to get a good DCR with a cam that size.
Originally Posted by waterbug1999
Notching the pistons and all, I "should" be around 11.3.1 - 11.5.1 CR and I believe with the cam specs I gathered, the DCR is ~8.5-8.6... IF, I remember correctly.
Very interested in your numbers. I'll be doing something similar except with a 112 LSA and with ETP 215s milled down a bit.
Originally Posted by pianoprodigy
I get 11.4 SCR and 8.56 DCR.
Originally Posted by ringram
Sounds like 93 min for you buddy.
Originally Posted by 01ss#5536
Nice work dude. that thing should fly.
holiday on 78th & nic has 110 if you need some. don't know how much a gallon.
Originally Posted by CHIWS6
where did u get the flycutting tool? how did u get the back cylinder? BTW thats an AWESOME setup!!!!
The flycuttin tool I rented from LGM (169 + shipping). Just a dummy head and the "Isky" tool (I think thats what they call it).
The back 4 (2 on each side) you need to get the 90 degree adapter, you can buy at any hardware store. I bought this bendable/90 degree piece that i made fit the cutting tool and it went smooth. I also cut out the AC box (have not used the AC in 2-3 years so i got rid of it) and patched the hole so I had PLENTY of room to get the passenger side.
Its not as hard as you might think. Just be prepared to take the dummy head of a 100 or so times and keep checking your depth so you dont over cut.
#34
Hey Waterbug,
Great job, should run great. Believe it or not my car is still down, I got caught up with a business venture I'm in the middle of, and haven't had the time to finish my install. Heads have been off, and I just put the light springs on again to check clearance. What were the specs you used on the cam so I can figure my compression with my 225's. Really interested in seeing what it puts down but more importantly what it does down the quarter.
John
John
#36
Well, the car made 421.. Ill post up in the Dyno section once I get the graph scanned.
But, the TQ was kind of low though.
![](http://www.geocities.com/jody_abbott2000/transamdyno.jpg)
Really good #'s man. You should be happy.
TQ through the locked auto will always be low. Unlocked your at like 400, unless you flash it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If it matters for comparision my #'s were made with AFR 205's milled .024 and a 228 cam, no Fast/90 yet. I have a 3500 stall.
Congrats though, awesome.
#40
TQ through the locked auto will always be low. Unlocked your at like 400, unless you flash it.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
