Just curious. how much power?
Old May 31, 2006 | 12:11 PM
00pewterWS6TA's Avatar
Default Just curious. how much power?
just wondering how much HP it takes to get the front tires off the ground? or is there no set amount? im sure tires, gears ect. play a big role, but if anyone at the track is doing this and i know theres alot could youchime in with your hp/tq #'s. thanks nick
Old Jun 1, 2006 | 02:59 PM
ttt...
Old Jun 1, 2006 | 03:18 PM
Xtnct00WS6's Avatar
I can't speak from experience, but I think the front suspension has a lot to do with being able to raise the front tires. HP is a given, but I think there are shocks that are meant for lifting the front end. I'm guessing 600-650 (in a full weighted car) would be a starting point of what you'd need with the right setup to support the power.
Old Jun 1, 2006 | 05:56 PM
vodas00ss's Avatar
why in the hell would they make shocks, "intened for lifting up the front wheels"
Old Jun 1, 2006 | 06:07 PM
bene's Avatar
Trunion King
I'm more thinking about weight. Tube K member, A arms, manual steering, no A/C, lighter hood, skinnies,!stabilizer bars, !windshield washer tank, !bumper support, !foam,!DRL lights and fogs. Then your gears, stall(A4), suspension set-up,and HP/TQ.
Old Jun 1, 2006 | 06:16 PM
ive been thinking weight myself. and just enough hp/tq. ive just always had this dream to be at a spot light and launch that motha at 6k and wach peoples reaction.
Old Jun 1, 2006 | 06:24 PM
Humvee z28's Avatar
well we will see where this thread goes... my car was full weight stock shocks, no SFC, spohn panhard and LCA's is as far as suspension went. power mods was LM, tune, and 100 shot out of the hole. drivetrain mods were fuddle 3400/2.1 converter, stock 10 bolt with 3.73 gears, and a girdle. on motor the car put down like 280 rwhp, with 100 shot maybe 360ish. i pulled both front wheels a couple inches for a few feet. i was running 26x10.5x16 inch bias ply et streets. track was hooking good and well it pulled the front wheels. full weight, minus spare tire. just what i managed to do.
Old Jun 1, 2006 | 06:27 PM
thats excellent, so i guess its not so far off in the future. thanks for the replies.
Old Jun 10, 2006 | 07:34 PM
Wyckedcamaro's Avatar
people actually believe you NEED 600 horse to pull the fronts?
Guys.. if you dont KNOW the answer or even know ANYTHING why just spew out bullshit wrong answers.
YOU CAN PULL THE FRONTS WITH 300 RWHP.
Suspension and weight is the KEY.
Old Jun 10, 2006 | 07:59 PM
ssam98's Avatar
Suspension and weight is the KY.
Is that steve?
Old Jun 10, 2006 | 08:48 PM
Christian8A's Avatar
Thats what Im trying to do to... and well mine pulls the pilots tire like 8" and the other one maybe 3, so is not what I really was looking to.. most of people keeps telling me is the suspension, Sticky tires deffinitelly and weight like Wyckedcamaro said.. what Im trying to find out is what stuff to start with to balance the weight
Old Jun 10, 2006 | 08:59 PM
JL ws-6's Avatar
Race your car!
A heavy rear swaybar will even the car out alot.
As for the power to pull the tires... it's not as much a power thign as it is a traction and weight deal. If the car is spinning, the front tires are NOT coming off the ground. If the car's dead hooking, you're about 1/2 way there already. I've seen cars with 375 rw go on the bumper... so it's not all about power
Old Jun 10, 2006 | 09:00 PM
ls1muscle's Avatar
rear sway bar
As for the original question, get a torque arm, lca's w/relocation brackets, QA1 shocks, remove front sway bar. You've got a 4000 stall so that's good. Take weight off the front of the car, run skinnies up front, move battery to back, remove front bumper support, take out A/C, etc..
Old Jun 10, 2006 | 09:40 PM
ChocoTaco369's Avatar
Tech Resident
i've always had the dream of watching someone snapping even a 9" rear like a toothpick
but how sweet would it be to have a DD with wheelie bars? is that street legal? maybe that'll be a future appearance mod..
Old Jun 10, 2006 | 09:45 PM
SiL3NtXWS6's Avatar
why would he snap the 9inch like a toothpick..
Old Jun 10, 2006 | 10:16 PM
motoxlifer's Avatar
I doubt you'll ever be able to pull the wheels on the street. Unless your runnin some big slicks and do a big burnout there just isn't enough traction available on the street with street tires. Don't believe that fast&furious b/s, I think it is physically impossible to pull the front wheels and smoke the rear tires at the same time.
Old Jun 10, 2006 | 11:26 PM
cjels1's Avatar
theres a pic of a blue and yellow TA with a flagger pullin the wheels on a private street
Old Jun 10, 2006 | 11:28 PM
cjels1's Avatar
i dont htink it is
Old Jun 11, 2006 | 12:42 AM
Slow00ls1T/a's Avatar
nice pic bad photoshop
Old Jun 11, 2006 | 12:49 AM
Poor Kid's Avatar
I got the tires off the ground in a 00 Z28 with some 26x10.5 slicks and an NOS dry kit. Its pretty easy when you have traction, and a little power.
