Need new short block advice
Old May 31, 2006 | 05:08 PM
King James's Avatar
Default Need new short block advice
I recently found a crap load of metal shavings and chunks in my oil pan. I don't feel like trying to figure out the problem right now so I'm planning on ordering a new, forged short block. I have about $3600 and I'm not sure which direction to go to make the most out of my money. I'm hoping you guys (and gals) can give me some insight before I start calling the sponsors tomorrow.
The car right now has stock heads which were milled an unknown amount, full bolt-ons (minus EWP), G5X3, PP gold springs, Thunder pushrods, LS2 timing chain, 'King James' ported and shimmed (.060) oil pump, Midwest 4400 2.5 STR stall, mildly built trans, and 3.73 gears.
Old May 31, 2006 | 05:19 PM
Joel_SS's Avatar
Call LME and be done with it.. Let us know what you want out of the motor.. You just want a replacement, you want big cubes, gonna be running N20 or any turbo/super charger?
Old May 31, 2006 | 05:23 PM
Joel_SS's Avatar
I just installed a shortblock from LME I needed a stock replacment that could handle a small shot of N20 safely.. they sold me the following
LME 347
Weiseco 3.905 pistons
CA Dura Moly Rings
Stock Rods and Crank
ARP rod bolts
Fedral Mogul Main Bearings
Clevite rod bearings
Dura Bond cam bearings
Balanced and blueprinted
Patriot Stage 3 heads 2.055/1.57 59CC (11.3:1 compression)
slow trap's Avatar
most of the sponsors shortblocks are around $2800 or so,then you will need new gaskets and head bolts or studs.now would be the perfect time if you could save alittle more to get a set of the budget 243s.
Old May 31, 2006 | 05:31 PM
King James's Avatar
The car will more then likely get sprayed within the next year. For right now it is staying NA though.
I thought about trying to with a forged LS2 but I don't think that is going to fit into the budget.
Old May 31, 2006 | 05:45 PM
Joel_SS's Avatar
If your budget 3600 tops a forged LS2 will more than lickely be outta your price range. If you are gonna use your current heads you could get a really nice forged 347 to handle a big ole hit of nitrous. My setup should be pretty safe up to a 150 wet..
Old Jun 1, 2006 | 08:40 AM
TSDuke's Avatar
http://forums.corvetteforum.com/show...post1551987390
Old Jun 1, 2006 | 08:45 AM
King James's Avatar
Wow! That's awesome! Thanks for the link
