LS1 stock SCR
Old Jun 4, 2006 | 04:40 AM
PREDATOR-Z's Avatar
Default LS1 stock SCR
On the calcs that I use (with negative piston deck) I never get 10.1:1 SCR.
I know they do not take into account the gasket bore size.
But could that be the .018>.023 descripancy we get with calcs?
With -.005 piston to deck it is 10.28:1
and with -.007 it is 10.33:1
The only time I get close to the advertised numbers is if the piston to deck is 0, 10.17:1
Could someone shed some light on this?
Old Jun 4, 2006 | 11:24 AM
ShevrolayZ28's Avatar
Assuming 3.903" cylinder bore and 3.940" gasket bore, the difference in combustion chamber size that is overlooked is on the order of ~0.055cc. (Insignificant?)
https://ls1tech.com/forums/generation-iii-internal-engine/519073-simple-math-question.html
...I have no clue how much that changes SCR. Maybe you can plug that into the calculator and see what it's worth.
Old Jun 4, 2006 | 12:20 PM
oange ss's Avatar
what are you using for gasket thickness ?
Old Jun 4, 2006 | 12:27 PM
oange ss's Avatar
i got 10.21, using -.008 deck height, .060 gasket and 3.898 bore
Old Jun 4, 2006 | 02:35 PM
MSURacing's Avatar
are you taking into account the ring land volume?
Old Jun 4, 2006 | 03:53 PM
BLKWS.6's Avatar
the SCR on an LS1 is 10.25:1 I thought? LT1 is 10.5:1
Old Jun 5, 2006 | 12:54 AM
PREDATOR-Z's Avatar
My pistons were .007 out
and the stock gaskets .053 compressed.
3.898 bore
3.622 stroke
flatops = 0
Head chamber volume 66.67 ? (that is the only part I never measured)
Are the stock chambers larger than 66.67 ?
Chambers would be in excess of 68 cc for my original motor to be 10.1:1
There must something I'm missing?
I wanna knooooow
Old Jun 5, 2006 | 01:29 AM
stevensLS1's Avatar
i have no idea what yall are talking about so ill just keep on
Old Jun 5, 2006 | 02:49 AM
PREDATOR-Z's Avatar
I'm trying to figure out the stock LS1 static compression (at least the range)
A lot assume 10.1:1 but it seems more in the 10.2x:1
I just want to find out to adjust my DCR calculator.
Old Jun 5, 2006 | 08:54 AM
oange ss's Avatar
i thought they were advertised at 10.2:1...and i used 66.67cc chamber also...still not sure on gasket thickness, my stock graphite miced out at .054 uncompressed, i think they would compress at least another .003-.004...the whole gasket thing is still a mystery i guess
Old Jun 5, 2006 | 09:50 AM
MSURacing's Avatar
You need to take into account the ring land volume, which is the volume around the top of the piston right above the 1st ring. This will be:
Bore: 3.898"
Top Land Length: ~0.200"
Top Piston Diameter: 3.848"
Right above ring land: 3.854"
so, area=pi(r)^2
((3.854-3.848)/2)+3.848=3.851
3.851/2=1.9255
(1.9255)^2*pi()=11.648
(3.898/2)^2*pi()=11.934
(11.934-11.648)*.200=0.0572*(2.54)^3= 0.937cc's
So, you need to add 0.937cc's to your combustion chamber volume. I bet this will get you closer to your number!!!
Old Jun 5, 2006 | 12:18 PM
Bore: 3.898"
so, area=pi(r)^2
3.851/2=1.9255
Your calculation seems good to me, except I am not that familiar with the input values.
It looks like you did this calculation and that is what was called for.
Old Jun 5, 2006 | 12:27 PM
MSURacing's Avatar
RIght you are, I am going to keep that equation, sure is a lot shorter than the one I did!!!!
These are approximate numbers, I am not certain what the height or the slope of the angle on the stock piston is.
Old Jun 5, 2006 | 12:33 PM
Here's a direct calculator
http://www.abe.msstate.edu/~fto/tools/vol/cylinder.html
Old Jun 5, 2006 | 12:44 PM
PREDATOR-Z's Avatar
Yeah, that's what I thought ~ 67.37 "actual" chambers
