Disaster strikes solid roller, possibly wiped out cam..
Pulled the rockers and the pushrod was straight but the lifter end had some wear. At this point I am assuming that either the lifter is damaged or the cam lobe is gone. Either way its not going to be pretty.
Sorry to read of your setback, Phil. Hang in there.
Good luck sorting things out...
Tony M.
It sure does seem like those are two different pushrods or that one got beat to death and removed material from it, wow, that's crazy.
Also, I assume you meant .002 out on your original post and not .02 out. .02 is quite a drastic change. Good luck!
Do those lifters have priority oiling to the roller wheels?
Notice any excess metalic flakes in the oil lately? That pushrod looks like it's been beet up pretty good. Look at the crooked whitness mark that's been cut in it!
The wear on the shorter pushrod, shown in the photo, looks to have been shortened by wear, and some of the worn metal got stuffed into the oil passage.
*Disclaimer: There's a pretty good chance I don't know what the heck I'm talking about. I'm just trying to learn and participate in the discussion.
None of us know 100% what happened there, but we all try to help out however we can
Just thought I would further clarify my statement because there are also combinations that would run better with a heavier spring/ larger pushrod combination, but are much more short term drag race oriented....not the typical dual purpose applications most of the readers on here are running or looking to build.
JMO of course...
Tony
JMO of course...
Tony
. My car is a street strip setup, but no daily driver by any means and haven't even implemented this combination yet so it's hard for me to speak with 100% knowledge of what's going to pan out. I do have to rely on my short block builder though for this as i'd trust just about anything this guy has said and he seems to think I'll be fine driving around on the street with bigger then most would run lift and spring pressure wise. I'm speaking of Erik at HPE. I would've run 7/16" pushrods if I could've but didn't have enough room in my heads for them and the back of the trunion strap (to the push rod cup side) hit the pushrod and i'd rather use a 3/8" pushrod then grind even .005 from my rockers. I'm using 1.95 rockers though and will have very very fast valve action hence the need for my larger pushrods. This motor will only see 7500 rpm to. Most would indicate weight on the lifter side of the valve train is irrelevant (within reason ofcourse).
