2003 lm7
Old Jun 5, 2006 | 08:06 PM
sss275hp's Avatar
Default 2003 lm7
I have a 2003 5.3l in my truck and am going to put ls6 heads milled back to stock compression on and was going to put a cam in. I was thinking about the voodoo cam 60511 it has .567 lift. Do you think i should have the piston cleaance i nedd with .030 off the head with this lift. Also after this conversion should i still be able to run a full 150 wet shot of nos still. I have 3200 stall and 3.73 gears.Stock bottom end. Also anybody have a recomended pushrod lenght.
Old Jun 5, 2006 | 08:20 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, the PTV can't be determined off of lift alone. What are the rest of the specs?....Yeah I could go look at that particular voodoo cam, but I figured that you have them close by.
Old Jun 5, 2006 | 10:11 PM
sss275hp's Avatar
http://www.holley.com/data/Products/Technical/60511.pdf
Old Jun 5, 2006 | 10:12 PM
sss275hp's Avatar
I think it should work fine but just getting a popular opinion.
Old Jun 6, 2006 | 03:51 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, It looks like it will fit according to the cam card. 222/228 .567/.567 113°+4
Old Jun 6, 2006 | 08:37 PM
sss275hp's Avatar
Thanks just wanted to make sure.
Old Jun 6, 2006 | 09:25 PM
Quik's Avatar
what he said
