how often to replace springs?
Old Jun 6, 2006 | 08:50 PM
jlashley2001ss's Avatar
Default how often to replace springs?
im getting a comp custom grind XE-R lobe 224/228 .581/.588 110+2 LSA
w/ 918 springs and 7.425" PR How often or how long will the 918 springs last? its a DD and see track maybe twice a yr. TIA guys
Old Jun 6, 2006 | 09:15 PM
mattsls1's Avatar
Check them every 15k or so
Old Jun 6, 2006 | 09:17 PM
smokey1226's Avatar
thats good to hear, i was thinking like ever 1500 or so! Saves me a lot of work
Old Jun 6, 2006 | 09:28 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
1500?! You must have been thinking about adjusting valves in a volkswagen beetle!
Old Jun 6, 2006 | 09:36 PM
DuronClocker's Avatar
Assuming my springs can handle my cam this whole year, I plan on buying a new set of springs every year or so...though who knows if I'll have the car long enough to change them more than once or twice. I'm running Patriot Gold dual springs on my .641/.646 lift cam with LSK lobes.
Old Jun 6, 2006 | 09:37 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I need dual springs like a bum needs a shopping cart.
Old Jun 6, 2006 | 09:52 PM
wow i didnt think you had to change springs that often
Old Jun 6, 2006 | 10:08 PM
Patriot golds have higher open and seat pressures than the 918s, making the material more brittle and wears out faster. Not to mention the much higher lift .646" lift and and valve speed due to the high ramp rates of the LSK lobes (very aggressive).
Its not a terrible job, and I think the springs themselves are only like $150-160 tops since I already have everything else (retainers, seats, locks, etc.)
Old Jun 6, 2006 | 10:09 PM
tbojbob's Avatar
been there, done that!
Old Jun 6, 2006 | 10:10 PM
1baddls1's Avatar
w. that much lift id go conservativley with 10,000 miles to 15,000 not much more though (personally)
Old Jun 6, 2006 | 10:11 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have hit 14,000 with my current 244/248 cam...it can be done. This is on ti retainers and comp 26918-16's.
Old Jun 6, 2006 | 10:31 PM
with my setup i shouldnt have to change my springs for a while correct? Thanks for ape raping my thread guys
Old Jun 7, 2006 | 12:58 AM
Mike2kZ's Avatar
If I'm not mistaken, a dual spring set-up might hold up longer.
Old Jun 7, 2006 | 09:09 AM
I'd check your springs once a year, but I'd imagine they should last at LEAST 2-3 years (assuming 12-15k/year)
Old Jun 7, 2006 | 09:47 AM
Pewterme's Avatar
I just ordered an 228 232 588 592 110+1 with XER lobes but got the PRC dual springs. I've heard they should last 25 to 30,000 miles anyway.
Old Jun 7, 2006 | 09:51 AM
GuitsBoy's Avatar
I would go 20K miles, and then check spring pressures every 5K after that.
Old Jun 7, 2006 | 11:03 AM
thanks
Old Jun 7, 2006 | 01:58 PM
Speedpup's Avatar
I replaced mine at 1500 and the second set broke at 900. Track use only. Now going with comp 921 instead of Manley single. Rev limiter is set at 6700. Car is usually in the upper power band at the track and a gear lower in the turns than all ther cars.
Old Jun 8, 2006 | 02:52 PM
Chris Gage's Avatar
I wouod check them at 15k and about every 5k after
