which head is better
Old Jun 6, 2006 | 10:20 PM
c5_ls1_6spd's Avatar
Default which head is better
PRC LS6 CNC Ported Heads or the PRC LS6 Stage 2.5 CNC Ported Heads?
Old Jun 6, 2006 | 10:23 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Or. PRC 5.3 2.5 cnc ported heads.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Depends on what you are trying to acheive....higher compression?
Old Jun 6, 2006 | 10:28 PM
i just want to know what are the differences between those two heads? what does that 2.5 stand for also?
Old Jun 6, 2006 | 10:30 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Stage two and a half.
Old Jun 6, 2006 | 11:45 PM
SVT THIS's Avatar
Usually the "stages" are an increase valve sizes. What cam are you going to be running??
Old Jun 7, 2006 | 12:33 AM
DocEwww's Avatar
Increased vavle size and a matching vavle job. It'll flow better than the stock vavled stage 1 head but you'll be very limited in cam size with the stock pistons.
Old Jun 7, 2006 | 11:15 AM
jlashley2001ss's Avatar
whats the advantages of higher compression?
Old Jun 7, 2006 | 11:27 AM
i was looking at the g5x3 cam or ms3 cam on a 112lsa. and i was wanting to run the PRC ls6 cnc ported stage 2.5 heads with the 2.04/1.575 valves
Old Jun 7, 2006 | 04:22 PM
2000TransAmWS6's Avatar
you will not be able to run bigger than stock valves with the MS3 without flycutting the pistons.
Old Jun 7, 2006 | 04:41 PM
Rescue Ranger's Avatar
Old Jun 7, 2006 | 05:15 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Rescue Ranger
What?! He asked what it meant!
Anyway, raised compression (static or dynamic) can essentially lead to more power, but along with that comes tighter quench and so forth.
