whp vs wtq
Old Jun 12, 2006 | 04:18 PM
NVR KNO's Avatar
Default whp vs wtq
hey. i have a question for you guys, it might be a dumb one but i just dont know the answer. i see these big lift cams making over 400 to the wheels easily, but the torque is no where near the same. take the ms3... most guys w/ manual transmissions are over 400whp but only like 370wtq. why are there no big torque numbers?
Old Jun 12, 2006 | 04:32 PM
2000TransAmWS6's Avatar
in a nutshell more duration will move your power band up higher, guys with huge cams are moving their power band so high that it is affecting their torque numbers.
so, its not really the lift that is hurting their low-end torque, its the duration.
bigger is not always better.
Old Jun 12, 2006 | 07:46 PM
eamador11's Avatar
at least your learning the right stuff. TQ is what makes you pull ahead and win races, especially on the street. you want to have a high but flat Tq curve as possible to have a great street car. that way your powerband is from mid to high where you will use it.
Old Jun 12, 2006 | 10:21 PM
HOSS's Avatar
Just have to choose the "right" cam. I am making damn good TQ numbers for a cam only car with that much power. Other cams produce big hp gains, but very lil torque.
Old Jun 13, 2006 | 03:57 AM
300bhp/ton's Avatar
Well as I see there's two sides to this.
Firstly is actual setup having a good DCR (dynamic compression ratio) with a well specced cam for the rest of the mods should offer a good low end and PEAK torque numbers.
The other side is HP is derived from torque:
HP = torque x rpm / 5252
So it means if your car makes 350lb ft and you mod the car so it know makes the same amount of torque but 500rpm higher in the rev range then it will produce more power but the torque figure wouldn't have changed.
In most cases the torque figure does actually increase but with "bigger" cams it will certainly move the torque up the rpm range which is what has the most affect.
Old Jun 13, 2006 | 05:51 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I got the short end of the stick for tq with my 244/248 cam. 422/378
Old Jun 14, 2006 | 12:14 PM
NVR KNO's Avatar
so there reall arent any cams out there that will make u produce 400+ tq to the wheels? i heard a few guys break the 400 tq mark with the torquer 2 cam, but other than that nothing.
Old Jun 14, 2006 | 12:26 PM
Photochop's Avatar
The new LSK lobed cams that are in development with various sponsors on this site, are showing higher torque numbers than previous due to better DCR (as mentioned above), tighter LSA, and higher lift (primarily on the intake lobe).
It all depends on where you want to make power, and what your goals are for the car.
I chose a larger proven cam because I do most of my racing at the track, my car is not my daily driver, already had a big converter (tci 4400), and I like the sound of a choppy cam over a medium sized one.
Old Jun 14, 2006 | 12:48 PM
NVR KNO's Avatar
well im the other way. i go to the track once in a while. most of the racing is on the highway. its not a daily driver either, maybe drive it a handful of times a month. i have a manual too. i do luv the sound of the choppy cams also.
Old Jun 14, 2006 | 12:52 PM
~JOSHUA's Avatar
My cam only 236/236 112 made 421/385 at the wheels.
If you want big torque you need juice or boost... or cubes. I'm going the boost route.. 600/600.
Old Jun 14, 2006 | 01:22 PM
under pressure's Avatar
I know this is a subjective point, but when evaluating a cam selection, dyno results are just part of the picture. You really need to factor in the track or driving performance also. Some cars with lower dyno torque numbers for instance may run much quicker on the street than cars with higher torque numbers on their printouts.
Old Jun 14, 2006 | 01:57 PM
GuitsBoy's Avatar
Torque is really produced by dynamic compression. It just so happens that smaller cams usually have more dynamic compression because the intake valve closes earlier. Now increasing the duration does not actually lower torque itself. As stated, it raises the torque powerband. The bigger cam may make the same torque, but now its at a higher RPM and therefore makes more HP. If it were really a question of the larger the duration the less torque, then the stock cam would be walking all over the 224, 228, f-13 and torquer 2 in torque numbers.
Old Jun 14, 2006 | 02:15 PM
exactly!
Old Jun 14, 2006 | 02:55 PM
NVR KNO's Avatar
never looked at it like that. thanx for helping me understand.
Old Jun 14, 2006 | 03:35 PM
jpat1023's Avatar
good thread
Old Jun 14, 2006 | 03:48 PM
Wnts2Go10O's Avatar
cubes, duration, ramp rate, air velocity, compression, etc. you can only get so much low end with a 346 with 10:1
Old Jun 14, 2006 | 05:23 PM
davered00ss's Avatar
Moderator
Heads & higher compression (milled heads) will up the rwtq.
Old Jun 14, 2006 | 05:59 PM
NVR KNO's Avatar
thats what i was going to do once i put the cam in. i was just deciding on which cam to go with, but ive narrowed it down to pretty much the ms4(when it comes out) or the torquer v2.
