Heads arrived today - pics/specs/flow numbers
#42
Between hearing stories of people's cometics leaking and using copper gasket on my last set, I went ahead and did it again this time, but with a light coating. It worked for me before, so I didn't want to take the risk of leaks after putting so much time into the process.
#43
Update: I just pulled the plugs. Here are the pics:
Looking from the front of the car back (left side is passenger side):
![](http://img163.imageshack.us/img163/7439/lookingfromthefrontofthecarsma.th.jpg)
Passenger side plugs top view:![](http://img236.imageshack.us/img236/4999/passsidetopviewsmall6pg.th.jpg)
Driver side plugs top view:
![](http://img460.imageshack.us/img460/5921/driversidetopviewsmall7jh.th.jpg)
I also just found out that my last fillup at a gas station I don't usually go to contained 10% ethanol. I'm sure that can't be great for the car at this point.
#44
Originally Posted by PewterY2KZ28
I am running some of Xfactor's handy work.. just had my heads installed Wednesday..
I am running Brandon's Stage 1 port job, stock valves on my LS6 heads..
Mine flow right around 308-310 cfm... ( Brandon, correct me if i am wrong)...
Coupled with full bolt-on's, Yank SY3500,true duals "out the back", RPM4 cam (232/236 .595 .601 114).. my car made 400rwhp/375rwtq.. I picked up 23hp with the heads.. Not too shabby for an A4 with 323's with a simple port/polish.
Good luck with your car bro... i hope things work out for you..
[IMG]
[/IMG]
[IMG]
![](http://img147.imageshack.us/img147/6035/dyno3400hp8ci.png)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Brandon
#45
Brandon
#47
Originally Posted by xfactor_pitbulls
Is it just me or does the entire drivers bank look like it has been running more lean than the passenger side? There is definatley a difference in the coloring. I dont know what else to tell you to check at this point.
Brandon
Brandon
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#48
Brandon
Brandon
#50
Originally Posted by DaleMX
If it runs ok until it goes closed loop then maybe it's an O2 sensor gone bad from coolant contamination.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#51
In my other thread in the Eastern Members section Mikey hit it right on... I have an exhaust leak in the MC's since the exhaust is slip fit (and has been leaking since day one). Needless to say, it got worse since the exhaust was dropped for a couple weeks. I put some exhaust sealer just for the meantime and the thing ran friggin great. The throttle response is crisp as hell and you can tell the thing wants to run
The bad part is the sealant gave way halfway home and it started running like crap again. At least I know exactly what it is now! I may just flatbed it to the shop in MD where I'll get my exhaust all welded together and dual e-cutouts in
I'm so relieved I found the culprit with the help of Mikey... as soon as he said it, it just clicked. Thanks for all the help guys! I'll be taking it to the shop on Monday so I'll keep everyone updated.
Brandon
#52
Very glad to hear you have it figured out. I know how it feels to have an issue like that and not have the answer. Let us know how it does after you get the exhaust sealed up.
Brandon
Brandon
