Heads arrived today - pics/specs/flow numbers
Sent my 317's out a couple weeks back to get ported by a member on the board here. They arrived today and of course I had to take a couple pictures . The heads will be going on tomorrow and hopefully it will be back up and running by Thursday. Here's the rundown of what it got:
Intake valve: 2.08 Ferrea 6000 with 28* back cut
Exhaust valve: 1.60 Ferrea 6000
Intake port work: Stage 3 with upgraded intake seat, hand blended high lift valve job
Exhaust port work: Stage 2, width to accommodate 1 3/4" header
Flow numbers on super flow 600 with flocom at 28":
Valve Lift Intake CFM Exhaust CFM*
0.200 142 115
0.300 211 151
0.400 254 178
0.500 295 200
0.600 322 219
0.700 325 222
*The exhaust numbers are without a pipe.
Just thought I would share with you all. I can't wait to get it running and get some new dyno numbers
0.200 142 115
0.300 211 151
0.400 254 178
0.500 295 200
0.600 322 219
0.700 325 222
Good luck getting back and running. No doubt you are anxious from having the car down for a month. Let us know how she drives.............oh yeah you dont even have to wait for spring break in, so let her rip when she gets good and warm.
Brandon
Brandon
Brandon
Brandon
I may or not be able to monitor A/F depending on whether I get my gauge in or not, but do you think it would be alright to rip this thing out without a tune? I have a custom tune already for my other mods, but I just want to make sure I'm not gonna F anything up.
Originally Posted by ArcticZ28
You read my mind Just gotta make sure the A/F doesn't get too whacky during WOT.
The new heads should not effect your A/F much at all. As long as your tune was ok before with that cam.
Yeah the a/f lower in the rpm range being off a point or two isnt going to kill anything. The higher rpm a/f should not change very much at all. If your O2 sensors are doing their job anyways.
Brandon
Brandon
Brandon
Brandon
