will i break 400 RWHP with this set up
my goal all along has been 400 RWHP or more...
My set up, once all installed will consist of:
full bolt ons
TD's, LT's
FAST90/NW90
TSP 225/225 on a 112 (under.600 of lift, forgot it at the moment)
Patriot Stage II 5.3L heads w PP Gold dual springs and TSP hardened PR's
...and a tune
I am worried the cam may not get me there...
full bolt ons
TD's, LT's
FAST90/NW90
...and a tune
full bolt ons
TD's, LT's
FAST90/NW90
...and a tune
full bolt ons
TD's, LT's
FAST90/NW90
...and a tune
If you just want a high dyno number make sure your tyres are highly inflated ~35-40psi as this will reduce firctional loss.
Sit some ice packs ontop of the intake manifold.
Don't correct to SAE leave it at STD reading.
Make sure you use a Dynojet and not a Mustang Dyno.
Don't use any graph smoothing.
And switch the wiper blades on for the run.
If you really want to cheat, dyno run in the wrong gear to throw the dyno out.
Of course such a number would be total BS and bear zero relavance to the real world or SAE Net figures quoted by manufacturers.
If you want a more "real" world reading and something you can use to compare to SAE Net numbers then you'll need to correct to SAE, run sensible graph smoothing and use a load bearing dyno such as a Mustang dyno.
For example, SAE correction can easily reduce PEAK numbers by 3-10rwhp. Graph smoothing can easily show 5-15rwhp variation over the top. An dyno types can really affect the results big time.
400rwhp Dynojet is about the same as 374rwhp on a Mustang Dyno.
hey doug, i agree with everything said...
thats cool...dunno what im going to dyno the car on yet...i already dyno'd it on a stang dyno...sooo
maybe ill keep it at that to keep everything relavant!
Thanks man
Thanks man
i guess my next question was this:
I was originally going to go with a TSP T2....liked the numbers, but heard it isnt always streetable...
I went with the 225/225 because it was a solid spec'd cam...plus the $$ was
But I am still contemplating going with the T2....I really dont want to swap a cam twice!!
