Everything I need for cam?
Old Jun 17, 2006 | 01:57 PM
dnm12's Avatar
Default Everything I need for cam?
I have 112K and I am going:
(1) Reverse Split cam or CheatR package from Thunder Racing:
Thunder Racing LS1 Cam Swap Package w/ Dual Valve Springs Includes:
- Crane Cams 144832-16 Valve Springs
- Crane Cams 144661 Titanium Retainers
- Crane Cams 144460-16 Hardened Seats
- 11-VS-UV5001-EO Valve Stem Seals
- Thunder Racing Stock Length Pushrods (7.400)
(2) Ported LS6 oil pump
(3) JWIS Timing Chain
(4) Lifters...
(5) Gasket Kit, o-ring for oil pickup tube
To install:
Moore Spring tool
JPR Stix
Is there anything else I am missing
Old Jun 17, 2006 | 02:13 PM
Hennytime's Avatar
i would look ingto replacement lifters since you have a few miles on your motor, or the LS7 lifters...
Old Jun 17, 2006 | 02:56 PM
ShevrolayZ28's Avatar
Pushrod length checker, gasket kit, and an o-ring for the oil pick-up tube.
Old Jun 17, 2006 | 03:01 PM
Fratsit's Avatar
If you dont mind my asking.....
How much did that cam package cost you?
I have narrowed down my cam selection to 3 different bumpsticks, but would like a ballpark figure before I call TR.
Thanks,
R/
Frat
Old Jun 17, 2006 | 03:03 PM
dnm12's Avatar
1-3 around $1150
Old Jun 17, 2006 | 03:05 PM
Fratsit's Avatar
Originally Posted by dnm12
1-3 around $1150
Right on...thanks Good luck on the install.
R/
Frat
Old Jun 17, 2006 | 03:08 PM
dnm12's Avatar
Reverse Split-230/224 .575/.563 111 LSA 2200-6800 RPM Power Band. Excellent mid-range & high RPM power
CheatR-214/230 .601/.578 117 LSA. Off Idle-6800 RPM Power Band. Broad power range.
(4) Lifters...
To install:
Moore Spring tool
JPR Stix
Old Jun 17, 2006 | 03:22 PM
xaon's Avatar
If you are going to install new lifters, then you will need new Head Gaskets and bolts as well. The heads must be removed on these motors to replace lifters.
Other than that.. unless you already own the More Performance tool, you won't be able to purchase it. They are out of business and nobody has them in stock anymore... why they even continue to list it on their web page is beyond me.
Old Jun 17, 2006 | 04:15 PM
dnm12's Avatar
umm good point so no lifters and no more tool darn it....
Old Jun 17, 2006 | 08:59 PM
dnm12's Avatar
what about raidator fluid, oil/filter for oil change, and cam-lube or no?
Old Jun 17, 2006 | 09:19 PM
xaon's Avatar
you'll need some new radiator fluid, you don't HAVE to change your oil at that time... I've done it several times without changing the oil. You need no cam-lube, just lube it down with some fresh oil and stab it in.
Old Jun 17, 2006 | 09:26 PM
blkZ28spt's Avatar
Check the link in my sig.
I recommend picking up spare valve stem retainers/locks when you get the new oil pump O-ring at your local dealer. They are very easy to lose.
Old Jun 17, 2006 | 09:30 PM
Joel_SS's Avatar
I would go with the Patriot Sping kit. Hell of a lot cheaper than the Crane stuff, and just as good if not better. Also use the 5/16 wooden dowel. 2 dollars from home deopt, and get then crane cam sping tool..
Old Jun 17, 2006 | 11:59 PM
dnm12's Avatar
alright other then that is my cam size good i am going to regret anything later? keep in mind a may be getting some AFR 205 down the road (aways down the road)....
Old Jun 22, 2006 | 05:36 PM
dnm12's Avatar
Purchased!
-230/224 LSA 111 Cam
-PRC Dual Springs
-Hardened chromoloy pushrods
-Titanium retainers
-LS6 ported oil pump
-JWIS non-adjustable timing chain
-Gasket kit
-O-ring for oil pump
-Moore Tool
Old Jun 22, 2006 | 05:55 PM
blkbird's Avatar
How about a longet balancer bolt? Made my install easier.
Old Jun 22, 2006 | 09:48 PM
dnm12's Avatar
i believe it comes with everything i bought, i will ask thunder tommarrow. Hopefully I will see super low 12's/ high 11's (with the bfg's out back maybe as opposed to the nitto's)
Old Jun 22, 2006 | 10:51 PM
dnm12's Avatar
what about exhaust and intake seals
Old Jun 23, 2006 | 12:08 AM
Joel_SS's Avatar
yes you will need thos since you will also be replacing teh spring seats. If the PRC kit is like the patriot spring kit it will have them
Old Jun 23, 2006 | 12:17 AM
dnm12's Avatar
oh yeah.......
