Trick Flow heads track results
Old Jun 17, 2006 | 10:23 PM
JNorris's Avatar
Moderator
Default Trick Flow heads track results
I hit the track last night with the new TEA Trick Flow heads and I was impressed.
First off it has been really hot here in Montgomery, Al but it is never too hot to go the track and run a new setup!
Below is my best pass of the night.
60ft –---- 1.54
330 ------4.580
1/8-------7.15
MPH------95.46
¼--------11.26
MPH-----119.41
The DA was around 2000ft. My race weight was ~3420.
John
Old Jun 17, 2006 | 10:28 PM
Studytime's Avatar
60ft –---- 1.54
330 ------4.580
1/8-------7.15
MPH------95.46
¼--------11.26
MPH-----119.41
John
What is an "LG" cam? Specs? Range?
Ben T.
Old Jun 17, 2006 | 10:33 PM
JNorris's Avatar
Moderator
Ben T.
Good question!
The LG cam is a good ole single pattern 230/230 .595/.595. Small by todays standards.
Hugger's Avatar
Those are great times for that DA!
Old Jun 18, 2006 | 08:15 AM
Studytime's Avatar
Not bad at all. Do you have track results from before the head swap?
Very impressive.
Ben T.
Old Jun 18, 2006 | 09:28 AM
JNorris's Avatar
Moderator
Very impressive.
Ben T.
Before these heads the DA would have to be 800ft or lower to run the same times. So I feel sure that these heads lowered my ET by around .1- .15.
John
Old Jun 19, 2006 | 01:32 PM
Mike@TEA's Avatar
Cool keep us posted on your results!
Old Jun 19, 2006 | 02:41 PM
exSSer's Avatar
Are my heads done yet?
Old Jun 19, 2006 | 06:01 PM
mike c.'s Avatar
You think the heads lowered your ET by .1 to .15 only a tenth? what heads did you have on before? I had speed inc r.g.r st2 heads and went to the AFR 205's(59cc) and i went from the LG g5x2 to the g5x3 cam(cam was worth 10hp) i went from 11.7's 117mph to 11.1's 124. by the way....11.2's in the 1/4mi is hauling ***,congrats.
Old Jun 19, 2006 | 07:40 PM
JNorris's Avatar
Moderator
Thanks for the positive comments but I do not think I have done a very good job of explaining just how good these heads really are.
These Trick Flow heads are replacing a great set of TEA stage 1.5 heads that with a 224/224 cam put the car in the high 10s at 10.98 @ 122.46 on a 1.50 60ft. The DA was -300ft or so. With a 230/230 cam and the same TEA heads the car ran a 10.91 @ 122.64 on a 1.48 60ft. The DA was -1100ft. The car is no stranger to quick runs. Needless to say TEA puts out a great ported 5.3 head that are a very hard act to follow.
For my old TEA heads to run 11.26 @ 119.47 the DA would have had to be about 800ft or better. Explained in another way, my old setup would have run about an 11.40 in the same weather conditions that the Trick Flow heads ran an 11.26 in.
There are many, many factors that affect the ET a car runs such as your race weight, the weather conditions (DA), 60ft time, and others. Unless you document the race trim, mods, and weather conditions on every pass (which I do) it is very difficult to compare the gains that you see from one mod to the next.
One thing I am sure of is that the .1-.15 improvement in ET with the Trick Flow heads over my old setup is significant.
There is no question that these Trick Flow heads will put the car in the 10.80s in negative DA weather.
John
Old Jun 20, 2006 | 09:58 AM
Mike@TEA's Avatar
John
Well said! It's safe to say that the old 10hp=a tenth really doesn't apply when you start running 10.90's in a heavy street car.
