permission to go nuts?!
Oil pressure would probably smah it to smithereens if it was plugging up a passage as soon as the motor got pressure. I did see a couple flying around about an hour after it crawld into there...hopefully he was one of them. If not then I am not going to worry about it...well until it becomes a problem
what the hell happened to steve irwin anyways - it seems he just disappeared!
Obtw, I spun #6 rod last week and as all my friends looked in disbelief at the last gasps of my motor I calmly thought deja vu and then I remebered the Infamous Lithium thread. No worries, forged bottom end on the way with, 9in ford rear, and suspension upgrades. I got into the 11's with the stock bottom end, and the 10 bolt rear lived. Anybody need a 10 bolt?
Ill take those 3.23s
In any case my opinion is:
Engine = fine
Bug = dead!!!
UNLESS the bug was dragging a paper towel into your engine!
Best of luck to you. You above anyone else should have a sense of humor about this stuff by now...
After reading your post with 1,000,000 responses, I just imagined that bug dragging a paper towel into your engine before you could kill it.
