HELP! Compression and leakdown results, possible blown headgasket?
Was smoking constantly white/blue smoke very heavy.
I pulled the plugs and #5 is wet and covered in oil.
Compression test - 5 cylinder was about 30-45 psi, #7 was at 90psi all others were at 160psi (cold)
Leakdown - I'm getting 0% on #5
Coolant in Rad seems to be low, car was never overheated.
What's my next step, pull off the head to check the headgasket? Can you actually see on the gasket when it's blown?
Any other suggestions as to check before I remove the head?
So I have to drain the rad and engine block before I pull it then? Or can I just stick a towel over it once I pull the head?
