Is this a streetable cam?
Also what heads are you looking at? Stage 2 is a little vague as heads can vary quite a bit.
The Hot cam will give the motor a new edge and a more agressive idle but it won't totally transform the car.
Personally I'd look at something a little more racey. Thunder Racing offer some nice cams, a good starting place IMO is the TR224/224 is should still be pretty tame and suitable as a DD for just about anyone interested in cars but without any real negative affects. But it'll still make power, couple it together with some AFR heads and rwhp should be very nice indeed.
Or if you want something more out there just go cam only on one of the wilder setups, idle will be rougher, low rpms won't be as smooth and you'll get the noticable feeling of the motor coming "on-cam" but it will make very good power. Something like the Trak cam from Thunder Racing would be considered one of the more extreme cams but many still daily drive such setups.
Also worth a look is Texas Speed & Performance, they offer some great value packages. They have a nice range of cams, including some new ones just released. The MS4 is likely to be a beast, but would make a great street/track racer. Also their LS6 CNC ported heads are great value for money, not as good as the AFR's but then they are a lot cheaper
What car do you have and mods (if any)?
Basics to include on a cammed or h/c setup should be full exhaust, headers, high flow cats if you are running them, lid or CAI, stock ported TB and a LS6 intake manifold. Many of these items you could "upgrade" but consider this as the entry level point. Is your car auto or manual? If auto you'll be wanting a stall, probably around 3500rpm as a starting point, I'd check out Fuddle Racing and/or Yank Converters. You may also want to think about changing your final dirve ratio gears, auto's tend to go for 3.42, 3.73 or sometimes 4.10 and M6 cars 4.10's.
Also, LS2 timing chain, ported LS6 oil pump and cam install kit with the correct grade of springs are all needed. Plus a TUNE!
If you want power go with something different. The above mentioned TR224 is a great place to start. I suggest a TR224 on a 114 LSA with a good tune.
*If you don't want an aggressive cam (I assume you mean no lope) so as to avoid extra attention from the police you do not want the Hotcam anyway.
You will need to replace the valvesprings more often, though. Figure 20-25k miles or so.
what car do you have.
