Help IDing these springs/retainers/locks. Pics inside.
The parts are off a set of ARE stage II heads that were purchased a couple years ago before ARE went under.
If theres a shop out there that I can send the pieces to and have them identified for certain and have a new set shipped out let me know. http://www.compcams.com/technical/Ca...106-07/287.pdf
There are a couple differnet ones.
If anyone has used ARE before and has any idea what springs/valves might be in their stage II heads, please speak up. I'm really lost here...
From their website:
Wider angle (10°) locks to better distribute the ever increasing valve spring loads over the retainer than typical 7° locks, reducing the chance of "pull-through" failure.
Precision machined rather than stamped for the ultimate in accuracy.
Super tough, fatigue resistant alloy material.
Inside tang to taper relationship held tightly for repeatable valve spring installed heights.
Available for many popular valve sizes with and without a lash cap recess.
Also available in +.50" installed height versions.
For simplicity, any Super Lock™ fits any COMP Cams® 10° retainer. Just choose the correct lock for your valve size and applications.
Super Locks™ are recommended in all race applications because of their superior strength.
Can someone please tell me what a lash cap is? And whether or not I need them?
Pic of the super locks....
Do they look like my originals? It's hard to tell for sure because the pic on comps website isn't very clear...
PS I don't know why such large springs/retainers/locks were used...its not a large cam at all...something like 226/226 .58X/.58X on a 114lsa (as far as I can remember).
