torquer v2 dyno results
Old Jun 20, 2006 | 04:59 PM
Slow00ls1T/a's Avatar
Default torquer v2 dyno results
Im kinda disappointed in numbers
base run was max power 335 max torque 335
A/f was at 12 across until about 5000 was below 10 til 6200
after tune max power was 388 max torque was 369
a/f was 13 across the board
tune was by NLP
here is graph
hopefully with ls6 and underdrive I can break 400 mods are in sig except true duals instead of loudmouth
Old Jun 20, 2006 | 05:03 PM
co.6z28's Avatar
that was with ls6 heads also?
Old Jun 20, 2006 | 05:10 PM
BriancWS6's Avatar
What type of dyno?
Old Jun 20, 2006 | 05:13 PM
dyno jet with the ls6 heads
Old Jun 20, 2006 | 05:15 PM
DWillTA's Avatar
Do you have a dyno graph to post up?
Dave
Old Jun 20, 2006 | 05:18 PM
I do but scanner isnt working right now
Old Jun 20, 2006 | 05:21 PM
DWillTA's Avatar
Those numbers really suck. I feel for you. Something has to be wrong. What are the particulars on the heads (ie chamber size, milled, DCR, SCR, etc)?
Dave
Old Jun 20, 2006 | 05:37 PM
runninfast's Avatar
ya something has to be wrong , i have the torquer 2 with stage2 LS1 heads and i make 430 @395 tq on a dynojet .
Old Jun 20, 2006 | 05:58 PM
slow trap's Avatar
something definitely isn't right,that is within a few hp of my setup when i was cam only with a 228/228.even though you still have the ls1 on there i would think you are down on power,with a ls6 you should be in the 430 range but i don't think you will pick that much up so something is out of whack.
Old Jun 20, 2006 | 06:07 PM
Gto2789's Avatar
How bout an intake, i don't see one listed in the sig
Old Jun 20, 2006 | 06:09 PM
Sprayed1998's Avatar
I made 401 with that cam and stock heads with the stock ls1 intake too, all cars will be different.
Old Jun 20, 2006 | 06:34 PM
co.6z28's Avatar
made 408 hp cam only, somthing isnt right
Old Jun 20, 2006 | 06:38 PM
black_z's Avatar
Intake is holding you back big time.
Old Jun 20, 2006 | 06:53 PM
Bill Bowling's Avatar
Talking
I made 401.2 HP with a torquer 1 with stock heads and an A4. M6 should be higher.
Bill
Old Jun 20, 2006 | 07:46 PM
i didnt think ls1 intake would hurt that much
He also said that his dyno is about 5 percent less then everyone else in area
Old Jun 20, 2006 | 07:48 PM
Ice Knight's Avatar
Hmm...something has to be wrong, as others have said....
Nice cam choice though.
Old Jun 20, 2006 | 07:49 PM
well the base tune was way off
Old Jun 20, 2006 | 07:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It does seem to be fairly low for a decent sized cam. Even with LS6 heads.
Old Jun 20, 2006 | 08:16 PM
updated first post with graph
Old Jun 20, 2006 | 09:55 PM
seth webster's Avatar
Im about to have the exact same setup, maybe ill send the cam back to get something bigger or the heads back to get some more compression.
That setup should have definetly broke 410rwhp though, good luck getting some better #'s
