alchohol engine internals
JC
A friend of mine that runs a sand rail has an alky big block setup on nitrous, and I've seen what he went thru getting it set up to run alcohol, rings and bearings, are a must at least at the start of every season for him and once during the season, and sand rails only race for 300 feet, they pull up, stage and go, then they shut them off and tow them back to the pits... on a street car, you'd be doing the rings and bearings over probably every month or so.
Stick with gas, there's plenty of power to be made with it, probably more then you'll ever need for anything you can drive on the street.
Also how about methanol engines. and if i do end up just stickin with gas i would still like to be able to boost the hell out of it when i race, how hard are those kits that injectect alky into the airstream on internals. thanks man i thank your the first one who had understood the concept of what im tryin to build.
JC
