FlyCutting/PTV issues/questions
Old Jun 22, 2006 | 02:54 PM
Mcduffys's Avatar
Default FlyCutting/PTV issues and questions. Insight Please.
I have a couple questions inregards to flycutting and ptv, due to a recent incedent that happened with my brothers car.
When flycutting are you suppose to make reliefs for both the intake and exhaust? Or does it depend on your heads and ptv clearance?
If you dont flycut enough and have pistons kissing valves, could this cause a rod bolt/bolts to stretch?
Old Jun 22, 2006 | 03:57 PM
Xtnct00WS6's Avatar
In my opinion you only need to make valve relief's when you have below recommended clearances. This could mean only making relief's on just the intake. Minimum clearance should be .080 on the intake and .100 on the exhaust. If you're below either of those, you should flycut to attain those clearances.
If the valves hit the pistons, you can say bye bye to your engine.
This is what will happen if you don't have the right clearances:
https://ls1tech.com/forums/generation-iii-internal-engine/515815-damage-engine-pics.html
Good info on the topic:
https://ls1tech.com/forums/showpost....64&postcount=6
Old Jun 22, 2006 | 05:22 PM
Mcduffys's Avatar
https://ls1tech.com/forums/showthread.php?t=515815
Ok his particular case, only the Intake valve was flycut when his head swap was done. Well roughly 800-1000miles later, he loses oil pressure and is down on power.
We tear it down and find that every piston but #4 has hit on the exhaust valve. Not enough to destroy a piston but enough to kiss each one and mark it to the point that they look as if they have been flycut(which was confirmed wasnt done by the shop). We also noticed on one of heads that the #7 piston hit quite a bit and more so than any other.
Next we tore down the bottom end to find that #7 rod bearing is toast. As well as the fact that is fused itself to #3. With further insepction ALL of the other bearings, rod bearings and main caps look almost brand new(very little sign of wear), considering the car has 65k on it.
Through out the whole motor we also found 2 different types of metal.
Aluminum and bearing metal(obviously from the toasted bearing.) We found the aluminum EVERYWHERE. the pan, the pick up tube, on the valves, etc.
The question in hand is what would of caused this?
Is it a PTV issue?
-Did the piston hit and caused pieces of aluminum to to destroy that bearing?
-Did pistions hit and cause the rod bolt on #7 to strech?
Is it Rod Bolt issue?
-Did the #7 rod bolt stretch under load, which inter caused the rest of the pistons to hit valves ?
Is it another issue?
-Did all the aluminum/metal that was found under the pick up tube casue it ?
-Is it another issue that is not being thought of?
Any help or insight would be appreciated. Thanks in Advance.
Old Jun 23, 2006 | 09:24 AM
Mcduffys's Avatar
bump.....
Old Jun 23, 2006 | 09:31 AM
Xtnct00WS6's Avatar
I'd be willing to be it was a PTV clearance problem. The valves are NEVER supposed to hit the pistons. If they hit on the exhaust side, and you have evidence of this, then that's probably it.
Those bits of metal from the pistons had to go somewhere, so to the pan they went.
Old Jun 23, 2006 | 09:48 AM
Mcduffys's Avatar
Exaclty what we were thinking. Since they didnt cut the exhaust side and all pistons had kissed valves except #4.
Im thinking since the pickup tube sits over #3 and #7 all the metal that was being drawn to that area is what took out #7.
Any thoughts on that ?
Old Jun 23, 2006 | 02:49 PM
Patrick G's Avatar
LS1 Tech Administrator
The .080"/.100" clearance is a textbook figure for P to V. With wide splits between intake and exhaust duration, you'd be surprized how often the exhaust valve is the one that hits.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 23, 2006 | 03:18 PM
Mcduffys's Avatar
With them not flycutting the exhaust side, could this of caused the problem?
Because the installer is saying that it was due to rod bolt stretch and that alone. The only problem i find with that is the fact that all of a sudden 14 of 16 rod bolts stretched at the same time causing the pistons to hit. Intern causing the bearing to come apart?
Thanks again Pat.
Old Jun 26, 2006 | 11:31 AM
Mcduffys's Avatar
some more info and opinions on this would be appreciated.
